[petsc-users] SuperLU_dist issue in 3.7.4
Tue Oct 11 12:19:04 CDT 2016
This log looks truncated. Are there any valgrind mesages before this?
[like from your application code - or from MPI]
Perhaps you can send the complete log - with:
valgrind -q --tool=memcheck --leak-check=yes --num-callers=20 --track-origins=yes
[and if there were more valgrind messages from MPI - rebuild petsc
with --download-mpich - for a valgrind clean mpi]
Sherry,
Perhaps this log points to some issue in superlu_dist?
thanks,
Satish
On Tue, 11 Oct 2016, Anton Popov wrote:
> Valgrind immediately detects interesting stuff:
> ==25673== Use of uninitialised value of size 8
> ==25673==    at 0x178272C: static_schedule (static_schedule.c:960)
> ==25674== Use of uninitialised value of size 8
> ==25674==    at 0x178272C: static_schedule (static_schedule.c:960)
> ==25674==    by 0x174E74E: pdgstrf (pdgstrf.c:572)
> ==25674==    by 0x1733954: pdgssvx (pdgssvx.c:1124)
> ==25673== Conditional jump or move depends on uninitialised value(s)
> ==25673==    at 0x1752143: pdgstrf (dlook_ahead_update.c:24)
> ==25673==    by 0x1733954: pdgssvx (pdgssvx.c:1124)
> ==25673==    at 0x5C83F43: PMPI_Recv (in /opt/mpich3/lib/libmpi.so.12.1.0)
> ==25673==    by 0x1755385: pdgstrf2_trsm (pdgstrf2.c:253)
> ==25673==    by 0x1751E4F: pdgstrf (dlook_ahead_update.c:195)
> ==25674==    at 0x62BF72B: _itoa_word (_itoa.c:179)
> ==25674==    by 0x62C1289: printf_positional (vfprintf.c:2022)
> ==25674==    by 0x62C2465: vfprintf (vfprintf.c:1677)
> ==25674==    by 0x638AFD5: __vsnprintf_chk (vsnprintf_chk.c:63)
> ==25674==    by 0x638AF37: __snprintf_chk (snprintf_chk.c:34)
> ==25674==    by 0x5CC6C08: MPIR_Err_create_code_valist (in
> ==25674==    by 0x5CC7A9A: MPIR_Err_create_code (in
> ==25674==    by 0x5C83FB1: PMPI_Recv (in /opt/mpich3/lib/libmpi.so.12.1.0)
> ==25674==    by 0x1755385: pdgstrf2_trsm (pdgstrf2.c:253)
> ==25674==    by 0x1751E4F: pdgstrf (dlook_ahead_update.c:195)
> ==25674==    at 0x1751E92: pdgstrf (dlook_ahead_update.c:205)
> And it crashes after this:
> ==25674== Invalid write of size 4
> ==25674==    at 0x1751F2F: pdgstrf (dlook_ahead_update.c:211)
> ==25674==    by 0xAAEFAE: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> ==25674==  Address 0xa0 is not stack'd, malloc'd or (recently) free'd
> ==25674==
> [1]PETSC ERROR:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably
> memory access out of range
> On 10/11/2016 03:26 PM, Anton Popov wrote:
> > On 10/10/2016 07:11 PM, Satish Balay wrote:
> > > Thats from petsc-3.5
> > > Anton - please post the stack trace you get with
> > > --download-superlu_dist-commit=origin/maint
> > I guess this is it:
> > [0]PETSC ERROR: [0] SuperLU_DIST:pdgssvx line 421
> > /home/anton/LIB/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> > [0]PETSC ERROR: [0] MatLUFactorNumeric_SuperLU_DIST line 282
> > [0]PETSC ERROR: [0] MatLUFactorNumeric line 2985
> > /home/anton/LIB/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: [0] PCSetUp_LU line 101
> > /home/anton/LIB/petsc/src/ksp/pc/impls/factor/lu/lu.c
> > [0]PETSC ERROR: [0] PCSetUp line 930
> > /home/anton/LIB/petsc/src/ksp/pc/interface/precon.c
> > According to the line numbers it crashes within
> > MatLUFactorNumeric_SuperLU_DIST while calling pdgssvx.
> > Surprisingly this only happens on the second SNES iteration, but not on the
> > first.
> > I'm trying to reproduce this behavior with PETSc KSP and SNES examples.
> > However, everything I've tried up to now with SuperLU_DIST does just fine.
> > I'm also checking our code in Valgrind to make sure it's clean.
> > Anton
> > > Satish
> > > On Mon, 10 Oct 2016, Xiaoye S. Li wrote:
> > > > Which version of superlu_dist does this capture?   I looked at the
> > > > original
> > > > error  log, it pointed to pdgssvx: line 161.  But that line is in
> > > > comment
> > > > block, not the program.
> > > > Sherry
> > > > On Mon, Oct 10, 2016 at 7:27 AM, Anton Popov <popov at uni-mainz.de> wrote:
> > > > > On 10/07/2016 05:23 PM, Satish Balay wrote:
> > > > > > On Fri, 7 Oct 2016, Kong, Fande wrote:
> > > > > > On Fri, Oct 7, 2016 at 9:04 AM, Satish Balay <balay at mcs.anl.gov>
> > > > > > wrote:
> > > > > > > On Fri, 7 Oct 2016, Anton Popov wrote:
> > > > > > > > Hi guys,
> > > > > > > > > are there any news about fixing buggy behavior of
> > > > > > > > > SuperLU_DIST, exactly
> > > > > > > > what
> > > > > > > > > is described here:
> > > > > > > > > https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
> > > > > > > > mcs.anl.gov_pipermail_petsc-2Dusers_2015-2DAugust_026802.htm
> > > > > > > > l&d=CwIBAg&c=
> > > > > > > > 54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_
> > > > > > > > JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=RwruX6ckX0t9H89Z6LXKBfJBOAM2vG
> > > > > > > > 1sQHw2tIsSQtA&s=bbB62oGLm582JebVs8xsUej_OX0eUwibAKsRRWKafos&e= ?
> > > > > > > > > I'm using 3.7.4 and still get SEGV in pdgssvx routine.
> > > > > > > > > Everything works
> > > > > > > > fine
> > > > > > > > > with 3.5.4.
> > > > > > > > > Do I still have to stick to maint branch, and what are the
> > > > > > > > > chances for
> > > > > > > > these
> > > > > > > > > fixes to be included in 3.7.5?
> > > > > > > > 3.7.4. is off maint branch [as of a week ago]. So if you are
> > > > > > > > seeing
> > > > > > > > issues with it - its best to debug and figure out the cause.
> > > > > > > > This bug is indeed inside of superlu_dist, and we started having
> > > > > > > > this
> > > > > > > issue
> > > > > > > from PETSc-3.6.x. I think superlu_dist developers should have
> > > > > > > fixed this
> > > > > > > bug. We forgot to update superlu_dist??  This is not a thing users
> > > > > > > could
> > > > > > > debug and fix.
> > > > > > > I have many people in INL suffering from this issue, and they have
> > > > > > > to
> > > > > > > stay
> > > > > > > with PETSc-3.5.4 to use superlu_dist.
> > > > > > To verify if the bug is fixed in latest superlu_dist - you can try
> > > > > > [assuming you have git - either from petsc-3.7/maint/master]:
> > > > > > --download-superlu_dist --download-superlu_dist-commit=origin/maint
> > > > > > Satish
> > > > > > Hi Satish,
> > > > > I did this:
> > > > > git clone -b maint https://bitbucket.org/petsc/petsc.git petsc
> > > > > --download-superlu_dist-commit=origin/maint (not sure this is needed,
> > > > > since I'm already in maint)
> > > > > The problem is still there.
> > > > > Cheers,
> > > > > Anton
