[petsc-users] SuperLU_dist issue in 3.7.4
Anton Popov
popov at uni-mainz.de
Tue Oct 11 08:48:28 CDT 2016
Valgrind immediately detects interesting stuff:
==25673== Use of uninitialised value of size 8
==25673== at 0x178272C: static_schedule (static_schedule.c:960)
==25674== Use of uninitialised value of size 8
==25674== at 0x178272C: static_schedule (static_schedule.c:960)
==25674== by 0x174E74E: pdgstrf (pdgstrf.c:572)
==25674== by 0x1733954: pdgssvx (pdgssvx.c:1124)
==25673== Conditional jump or move depends on uninitialised value(s)
==25673== at 0x1752143: pdgstrf (dlook_ahead_update.c:24)
==25673== by 0x1733954: pdgssvx (pdgssvx.c:1124)
==25673== at 0x5C83F43: PMPI_Recv (in /opt/mpich3/lib/libmpi.so.12.1.0)
==25673== by 0x1755385: pdgstrf2_trsm (pdgstrf2.c:253)
==25673== by 0x1751E4F: pdgstrf (dlook_ahead_update.c:195)
==25674== at 0x62BF72B: _itoa_word (_itoa.c:179)
==25674== by 0x62C1289: printf_positional (vfprintf.c:2022)
==25674== by 0x62C2465: vfprintf (vfprintf.c:1677)
==25674== by 0x638AFD5: __vsnprintf_chk (vsnprintf_chk.c:63)
==25674== by 0x638AF37: __snprintf_chk (snprintf_chk.c:34)
==25674== by 0x5CC6C08: MPIR_Err_create_code_valist (in
==25674== by 0x5CC7A9A: MPIR_Err_create_code (in
==25674== by 0x5C83FB1: PMPI_Recv (in /opt/mpich3/lib/libmpi.so.12.1.0)
==25674== by 0x1755385: pdgstrf2_trsm (pdgstrf2.c:253)
==25674== by 0x1751E4F: pdgstrf (dlook_ahead_update.c:195)
==25674== at 0x1751E92: pdgstrf (dlook_ahead_update.c:205)
And it crashes after this:
==25674== Invalid write of size 4
==25674== at 0x1751F2F: pdgstrf (dlook_ahead_update.c:211)
==25674== by 0xAAEFAE: MatLUFactorNumeric_SuperLU_DIST
(superlu_dist.c:421)
==25674== Address 0xa0 is not stack'd, malloc'd or (recently) free'd
==25674==
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
On 10/11/2016 03:26 PM, Anton Popov wrote:
> On 10/10/2016 07:11 PM, Satish Balay wrote:
>> Thats from petsc-3.5
>> Anton - please post the stack trace you get with
>> --download-superlu_dist-commit=origin/maint
> I guess this is it:
> [0]PETSC ERROR: [0] SuperLU_DIST:pdgssvx line 421
> /home/anton/LIB/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> [0]PETSC ERROR: [0] MatLUFactorNumeric_SuperLU_DIST line 282
> [0]PETSC ERROR: [0] MatLUFactorNumeric line 2985
> /home/anton/LIB/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PCSetUp_LU line 101
> /home/anton/LIB/petsc/src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: [0] PCSetUp line 930
> /home/anton/LIB/petsc/src/ksp/pc/interface/precon.c
> According to the line numbers it crashes within
> MatLUFactorNumeric_SuperLU_DIST while calling pdgssvx.
> Surprisingly this only happens on the second SNES iteration, but not
> on the first.
> I'm trying to reproduce this behavior with PETSc KSP and SNES
> examples. However, everything I've tried up to now with SuperLU_DIST
> does just fine.
> I'm also checking our code in Valgrind to make sure it's clean.
> Anton
>> Satish
>> On Mon, 10 Oct 2016, Xiaoye S. Li wrote:
>>> Which version of superlu_dist does this capture? I looked at the
>>> original
>>> error log, it pointed to pdgssvx: line 161. But that line is in
>>> comment
>>> block, not the program.
>>> Sherry
>>> On Mon, Oct 10, 2016 at 7:27 AM, Anton Popov <popov at uni-mainz.de>
>>> wrote:
>>>> On 10/07/2016 05:23 PM, Satish Balay wrote:
>>>>> On Fri, 7 Oct 2016, Kong, Fande wrote:
>>>>> On Fri, Oct 7, 2016 at 9:04 AM, Satish Balay <balay at mcs.anl.gov>
>>>>> wrote:
>>>>>> On Fri, 7 Oct 2016, Anton Popov wrote:
>>>>>>> Hi guys,
>>>>>>>> are there any news about fixing buggy behavior of SuperLU_DIST,
>>>>>>>> exactly
>>>>>>> what
>>>>>>>> is described here:
>>>>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
>>>>>>> mcs.anl.gov_pipermail_petsc-2Dusers_2015-2DAugust_026802.htm
>>>>>>> l&d=CwIBAg&c=
>>>>>>> 54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_
>>>>>>> JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=RwruX6ckX0t9H89Z6LXKBfJBOAM2vG
>>>>>>> 1sQHw2tIsSQtA&s=bbB62oGLm582JebVs8xsUej_OX0eUwibAKsRRWKafos&e= ?
>>>>>>>> I'm using 3.7.4 and still get SEGV in pdgssvx routine.
>>>>>>>> Everything works
>>>>>>> fine
>>>>>>>> with 3.5.4.
>>>>>>>> Do I still have to stick to maint branch, and what are the
>>>>>>>> chances for
>>>>>>> these
>>>>>>>> fixes to be included in 3.7.5?
>>>>>>> 3.7.4. is off maint branch [as of a week ago]. So if you are seeing
>>>>>>> issues with it - its best to debug and figure out the cause.
>>>>>>> This bug is indeed inside of superlu_dist, and we started having
>>>>>>> this
>>>>>> issue
>>>>>> from PETSc-3.6.x. I think superlu_dist developers should have
>>>>>> fixed this
>>>>>> bug. We forgot to update superlu_dist?? This is not a thing
>>>>>> users could
>>>>>> debug and fix.
>>>>>> I have many people in INL suffering from this issue, and they
>>>>>> have to
>>>>>> stay
>>>>>> with PETSc-3.5.4 to use superlu_dist.
>>>>> To verify if the bug is fixed in latest superlu_dist - you can try
>>>>> [assuming you have git - either from petsc-3.7/maint/master]:
>>>>> --download-superlu_dist --download-superlu_dist-commit=origin/maint
>>>>> Satish
>>>>> Hi Satish,
>>>> I did this:
>>>> git clone -b maint https://bitbucket.org/petsc/petsc.git petsc
>>>> --download-superlu_dist-commit=origin/maint (not sure this is needed,
>>>> since I'm already in maint)
>>>> The problem is still there.
>>>> Cheers,
>>>> Anton
