[petsc-users] create global vector in latest version of petsc
Barry Smith
bsmith at mcs.anl.gov
Wed Oct 5 20:57:39 CDT 2016
PETSc fortran programs should always end with .F90 not .f90 can you try again with that name? The capital F is important.
Barry
> On Oct 5, 2016, at 7:57 PM, frank <hengjiew at uci.edu> wrote:
> Hi,
> I update petsc to the latest version by pulling from the repo. Then I find one of my old code, which worked before, output errors now.
> After debugging, I find that the error is caused by "DMCreateGlobalVector".
> I attach a short program which can re-produce the error. This program works well with an older version of petsc.
> I also attach the script I used to configure petsc.
> The error message is below. Did I miss something in the installation ? Thank you.
> 1 [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> 2 [0]PETSC ERROR: Null argument, when expecting valid pointer
> 3 [0]PETSC ERROR: Null Object: Parameter # 2
> 4 [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> 5 [0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-1571-g7fc5cb5 GIT Date: 2016-10-05 10:56:19 -0500
> 6 [0]PETSC ERROR: [2]PETSC ERROR: ./test_ksp.exe on a gnu-dbg-32idx named kolmog1 by frank Wed Oct 5 17:40:07 2016
> 7 [0]PETSC ERROR: Configure options --known-mpi-shared="0 " --known-memcmp-ok --with-debugging="1 " --with-shared-libraries=0 --with-mpi-compilers="1 " --download-blacs="1 " --download-metis="1 " --dow nload-parmetis="1 " --download-superlu_dist="1 " --download-hypre=1 PETSC_ARCH=gnu-dbg-32idx
> 8 [0]PETSC ERROR: #1 VecSetLocalToGlobalMapping() line 83 in /home/frank/petsc/src/vec/vec/interface/vector.c
> 9 [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 45 in /home/frank/petsc/src/dm/impls/da/dadist.c
> 10 [0]PETSC ERROR: #3 DMCreateGlobalVector() line 880 in /home/frank/petsc/src/dm/interface/dm.c
> Regards,
> Frank
> <test_vec.f90><gnu-dbg-32idx.py>
