[petsc-users] create global vector in latest version of petsc
Hengjie Wang
hengjiew at uci.edu
Wed Oct 5 20:23:22 CDT 2016
I did.
I am using GNU compiler 5.4.0. I don't know if this matters.
Thank you
Frank
On 10/5/2016 6:08 PM, Matthew Knepley wrote:
> On Wed, Oct 5, 2016 at 7:57 PM, frank <hengjiew at uci.edu
> <mailto:hengjiew at uci.edu>> wrote:
> Hi,
> I update petsc to the latest version by pulling from the repo.
> Then I find one of my old code, which worked before, output errors
> now.
> After debugging, I find that the error is caused by
> "DMCreateGlobalVector".
> I attach a short program which can re-produce the error. This
> program works well with an older version of petsc.
> I also attach the script I used to configure petsc.
> First, did you reconfigure after pulling? If not, please do this,
> rebuild, and try again.
> Thanks,
> Matt
> The error message is below. Did I miss something in the
> installation ? Thank you.
> 1 [0]PETSC ERROR: --------------------- Error Message
> 2 [0]PETSC ERROR: Null argument, when expecting valid pointer
> 3 [0]PETSC ERROR: Null Object: Parameter # 2
> 4 [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html
> <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> shooting.
> 5 [0]PETSC ERROR: Petsc Development GIT revision:
> v3.7.4-1571-g7fc5cb5 GIT Date: 2016-10-05 10:56:19 -0500
> 6 [0]PETSC ERROR: [2]PETSC ERROR: ./test_ksp.exe on a
> gnu-dbg-32idx named kolmog1 by frank Wed Oct 5 17:40:07 2016
> 7 [0]PETSC ERROR: Configure options --known-mpi-shared="0 "
> --known-memcmp-ok --with-debugging="1 " --with-shared-libraries=0
> --with-mpi-compilers="1 " --download-blacs="1 "
> --download-metis="1 " --dow nload-parmetis="1 "
> --download-superlu_dist="1 " --download-hypre=1
> PETSC_ARCH=gnu-dbg-32idx
> 8 [0]PETSC ERROR: #1 VecSetLocalToGlobalMapping() line 83 in
> /home/frank/petsc/src/vec/vec/interface/vector.c
> 9 [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 45 in
> /home/frank/petsc/src/dm/impls/da/dadist.c
> 10 [0]PETSC ERROR: #3 DMCreateGlobalVector() line 880 in
> /home/frank/petsc/src/dm/interface/dm.c
> Regards,
> Frank
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161005/593bf9a9/attachment.html>
