[petsc-users] using DMDA with python
Somdeb Bandopadhyay
sb020287 at gmail.com
Tue Oct 4 21:47:53 CDT 2016
Hi again,
Please allow me to explain in detail here:-
1. I am using Zang's (jcp 1994) method for incompressible flow on
generalized collocated grid.
2. The main difference lies on the calculation of the grid matrix, for
which I am using Gaitonde et al (2002)'s work
3. I want to use python to set up the domain , grid(structured) and
boundary/initial conditions.
4. I want petsc to a) decompose the domain with dmda b) use ksp for
linear solver.
I * have not* used petsc4py rigorously , so before trying his venture I wnt
to know whether it is feasible or not, and if there is any example for
similar work (so that I can copy their approach, to be precise)
Have a very good day.
Somdeb
On Wed, Oct 5, 2016 at 10:23 AM, Somdeb Bandopadhyay <sb020287 at gmail.com>
wrote:
> Hi again Sir,
> Thank you very much for the quick response. I am planning to
> implement a mustiphase algorithm on collocated grid. I already qrote a C
> code for 2d case, but it wasn't very generalized . So for the final
> version, I intend to use python as a script to interact with PETSc kernels.
> Somdeb
> On Wed, Oct 5, 2016 at 10:12 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Oct 4, 2016 at 9:02 PM, Somdeb Bandopadhyay <sb020287 at gmail.com>
>> wrote:
>>> Dear all,
>>> I want to write a solver for incompressible navier stokes
>>> using python and I want to use PETsc (particularly dmda & ksp) for this.
>>> May I know if this type of work is feasible/already done?
>> How do you plan to discretize your system? DMDA supports only collocation
>> discretizations, so some sort of penalty for pressure would
>> have to be employed.
>> Thanks,
>> Matt
>>> I intend to run my solver in a cluster and so am slightly
>>> concerned about the performance if I use python with petsc.
>>> My deepest apologies if this mail of mine caused you any
>>> inconvenience.
>>> Somdeb
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161005/9507a3cc/attachment.html>
