[petsc-users] use of VecGetArray() with dof>1 (block size > 1)
Ed Bueler elbueler at alaska.edu
Fri May 27 18:18:16 CDT 2016
Dave --
You are right that I had a cut-paste-edit error in my VecGetArray()
invocation in the email.   Sorry about that.  I should of cut and pasted
from my functioning, and DMDA-free, code.
In this context I meant
Vec v;
...  // create or load the Vec
Node *u;
VecGetArray(v,(PetscScalar**)&u);
This *is* correct, and it works fine in the right context, without memory
leaks.  I am *not* using a DMDA in this case.  At all.
My original quote from the PETSc User Manual should be read *as is*,
however.  It *does* refer to DMDAVecGetArray().  And you are right that
*it* has an error: should be [j][i] not [i][j].  And DMDAVecGetArray() does
a cast like the above, but internally.
Again, my original question was about distinquishing/explaining the
different types of the returned pointers from DMDAVecGetArray() and
VecGetArray().
Ed
On Fri, May 27, 2016 at 2:47 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 27 May 2016 at 21:24, Ed Bueler <elbueler at alaska.edu> wrote:
>> Dave --
>> Perhaps you should re-read my questions.
> Actually - maybe we got our wires crossed from the beginning.
> I'm going back to the original email as I missed something.
>>> The recommended approach for multi-component PDEs is to declare a struct
>>> representing the fields defined
>>> at each node of the grid, e.g.
>>> typedef struct {
>>> PetscScalar u,v,omega,temperature;
>>> } Node;
>>> and write residual evaluation using
>>> Node **f,**u;
>>> DMDAVecGetArray(DM da,Vec local,&u);
>>> DMDAVecGetArray(DM da,Vec global,&f);
> 1)  The third argument to DMDAVec{Get,Restore}Array() is of type "void
>>> *".  It makes the above convenient.  But the third argument of the
>>> unstructured version Vec{Get,Restore}Array() is of type "PetscScalar **",
>>> which means that in an unstructured case, with the same Node struct, I
>>> would write
>>> "VecGetArray(DM da,Vec local,(PetscScalar **)&u);"
>>> to get the same functionality.  Why is it this way?  More specifically,
>>> why not have the argument to VecGetArray() be of type "void *"?
> Is the quoted text
> really what you meant?
> Sorry I didn't spot this on the first read, but probably you meant
> something else as VecGetArray() only takes two args (Vec,PetscScalar**).
> This code
>   Node **u;
>   VecGetArray(Vec local,(PetscScalar**)&u);
> would not be correct, neither would
>   Node ***u;
> if the DMDA was defined in 3d.
>> I would say the reason why the last arg to VecGetArray() is not void* is
>> because it is intended to give you direct access to the pointer associated
>> with the entries within the vector - these are also PetscScalar's
>>> 2) Given that the "recommended approach"
>> I don't believe it is ever recommended anywhere to do the following:
>>   VecGetArray(DM da,Vec local,(PetscScalar**)&u)
>> Trying to trick the compile with such a cast is just begging for memory
>> corruption to occur.
>> above works just fine, why do DMDAVec{Get,Restore}ArrayDOF() exist?
>>>  (I.e. is there something I am missing about C indexing?)
>> As an additional point, DMDAVec{Get,Restore}ArrayDOF() return
>> void *array
>> so that the same API will work for 1D, 2D and 3D DMDA's which would
>> require PetscScalar **data, PetscScalar ***data, PetscScalar ****data
>> respectively.
>> Cheers,
>>   Dave
>>> 3) There are parts of the PETSc API that refer to "dof" and parts that
>>> refer to "block size".  Is this a systematic distinction with an underlying
>>> reason?  It seems "block size" is more generic, but also it seems that it
>>> could replace "dof" everywhere.
>>> Thanks for addressing silly questions.
>>> Ed
>>> Ed Bueler
>>> Dept of Math and Stat and Geophysical Institute
>>> University of Alaska Fairbanks
>>> Fairbanks, AK 99775-6660
>>> 301C Chapman and 410D Elvey
>>> 907 474-7693 and 907 474-7199  (fax 907 474-5394)
> Ed Bueler
Ed Bueler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160527/deb03aa5/attachment.html>
