[petsc-users] use of VecGetArray() with dof>1 (block size > 1)
Dave May dave.mayhem23 at gmail.com
Fri May 27 17:47:56 CDT 2016
On 27 May 2016 at 21:24, Ed Bueler <elbueler at alaska.edu> wrote:
> Dave --
> Perhaps you should re-read my questions.
Actually - maybe we got our wires crossed from the beginning.
I'm going back to the original email as I missed something.
>> The recommended approach for multi-component PDEs is to declare a struct
>> representing the fields defined
>> at each node of the grid, e.g.
>> typedef struct {
>> PetscScalar u,v,omega,temperature;
>> } Node;
>> and write residual evaluation using
>> Node **f,**u;
>> DMDAVecGetArray(DM da,Vec local,&u);
>> DMDAVecGetArray(DM da,Vec global,&f);
1)  The third argument to DMDAVec{Get,Restore}Array() is of type "void *".
>> It makes the above convenient.  But the third argument of the unstructured
>> version Vec{Get,Restore}Array() is of type "PetscScalar **", which means
>> that in an unstructured case, with the same Node struct, I would write
>> "VecGetArray(DM da,Vec local,(PetscScalar **)&u);"
>> to get the same functionality.  Why is it this way?  More specifically,
>> why not have the argument to VecGetArray() be of type "void *"?
Is the quoted text
really what you meant?
Sorry I didn't spot this on the first read, but probably you meant
something else as VecGetArray() only takes two args (Vec,PetscScalar**).
This code
  Node **u;
  VecGetArray(Vec local,(PetscScalar**)&u);
would not be correct, neither would
  Node ***u;
if the DMDA was defined in 3d.
> I would say the reason why the last arg to VecGetArray() is not void* is
> because it is intended to give you direct access to the pointer associated
> with the entries within the vector - these are also PetscScalar's
>> 2) Given that the "recommended approach"
> I don't believe it is ever recommended anywhere to do the following:
>   VecGetArray(DM da,Vec local,(PetscScalar**)&u)
> Trying to trick the compile with such a cast is just begging for memory
> corruption to occur.
> above works just fine, why do DMDAVec{Get,Restore}ArrayDOF() exist?  (I.e.
>> is there something I am missing about C indexing?)
> As an additional point, DMDAVec{Get,Restore}ArrayDOF() return
> void *array
> so that the same API will work for 1D, 2D and 3D DMDA's which would
> require PetscScalar **data, PetscScalar ***data, PetscScalar ****data
> respectively.
> Cheers,
>   Dave
>> 3) There are parts of the PETSc API that refer to "dof" and parts that
>> refer to "block size".  Is this a systematic distinction with an underlying
>> reason?  It seems "block size" is more generic, but also it seems that it
>> could replace "dof" everywhere.
>> Thanks for addressing silly questions.
>> Ed
>> Ed Bueler
>> Dept of Math and Stat and Geophysical Institute
>> University of Alaska Fairbanks
>> Fairbanks, AK 99775-6660
>> 301C Chapman and 410D Elvey
>> 907 474-7693 and 907 474-7199  (fax 907 474-5394)
Ed Bueler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160527/3e2c7fd4/attachment.html>
