[petsc-users] Troubles with VecScatter routines: inverting vectors values
Tue May 24 11:37:02 CDT 2016
On Tue, May 24, 2016 at 11:22 AM, Alice Raeli <
alice.raeli at math.u-bordeaux.fr> wrote:
> Hi All,
> I had the necessity to read data on another node of a Vector Petsc.
> I followed the structure showed in the tutorial of VecScatterCreateToAll.
> I call the function below 2 times with 2 different vectors vec1 and vec2.
> void Scatter(Vec vec, PetscScalar &value, vector<int> NeighboursIndex, int
> NeighNumber){
>     Vec V_SEQ;
>     VecScatter ctx;
>     PetscScalar *vecArray;
>     VecScatterCreateToAll(vec,&ctx,&V_SEQ);
>     VecScatterBegin(ctx,vec,V_SEQ,INSERT_VALUES,SCATTER_FORWARD);
>     VecScatterEnd(ctx,vec,V_SEQ,INSERT_VALUES,SCATTER_FORWARD);
>     ierr = VecGetArray(V_SEQ,&vecArray);
>     for(int i=0; i<NeighNumber;i++){
>         PetscInt index=NeighboursIndex[i];
>         value = vecArray[index];
>         if(NeighboursIndex[0]==869 && (index==363 || index == 364 || index
> ==365) ){
>             cout << endl << index << "  inside function " << value;
>     ierr = VecRestoreArray(V_SEQ,&vecArray);
>     VecScatterDestroy(&ctx);
>     VecDestroy(&V_SEQ);
>     return;
> When I run my code with one node i have a result coherent but if I use 2
> nodes the vectors are inverted in values.
VecScatter just sends values. It does not process them in any way. You must
have other code in your program
that is altering the values. If you can send a small example, we will look
at it.
     Matt
> I used for a test a vector of 1 and a vector of 0 and I concentrated the
> output on a point that communicates with the other node.
> Can you explain me what is effectively wrong when I call the vecscatter
> routines? I can’t see a reason coherent with a simple inversion of values
> from 2 vectors.
> Example of output
> 1 node:
> first call vec1
> 364  inside function 87.797
> 363  inside function 89.0416
> 365  inside function 86.4618
> second call vec2
> 364  inside function 0.0268704
> 363  inside function 0.0322394
> 365  inside function 0.0199141
> 2 nodes:
> first call vec1
> second call vec2
> *Many Thanks*
> *Alice Raeli*
> *I*nstitut de *M*athématiques de *B*ordeaux *(IMB)*
> alice.raeli at math.u-bordeaux1.fr
> alice.raeli at u-bordeaux.fr
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160524/87510a28/attachment.html>
