[petsc-users] Troubles with VecScatter routines: inverting vectors values
Alice Raeli alice.raeli at math.u-bordeaux.fr
Tue May 24 11:22:39 CDT 2016
Hi All,
I had the necessity to read data on another node of a Vector Petsc.
I followed the structure showed in the tutorial of VecScatterCreateToAll.
I call the function below 2 times with 2 different vectors vec1 and vec2.
void Scatter(Vec vec, PetscScalar &value, vector<int> NeighboursIndex, int NeighNumber){
    Vec V_SEQ;
    VecScatter ctx;
    PetscScalar *vecArray;
    VecScatterCreateToAll(vec,&ctx,&V_SEQ);
    VecScatterBegin(ctx,vec,V_SEQ,INSERT_VALUES,SCATTER_FORWARD);
    VecScatterEnd(ctx,vec,V_SEQ,INSERT_VALUES,SCATTER_FORWARD);
    ierr = VecGetArray(V_SEQ,&vecArray);
    for(int i=0; i<NeighNumber;i++){
        PetscInt index=NeighboursIndex[i];
        value = vecArray[index];
        if(NeighboursIndex[0]==869 && (index==363 || index == 364 || index ==365) ){
            cout << endl << index << "  inside function " << value;
    ierr = VecRestoreArray(V_SEQ,&vecArray);
    VecScatterDestroy(&ctx);
    VecDestroy(&V_SEQ);
    return;
When I run my code with one node i have a result coherent but if I use 2 nodes the vectors are inverted in values.
I used for a test a vector of 1 and a vector of 0 and I concentrated the output on a point that communicates with the other node.
Can you explain me what is effectively wrong when I call the vecscatter routines? I can’t see a reason coherent with a simple inversion of values from 2 vectors.
Example of output
1 node:
first call vec1
364  inside function 87.797
363  inside function 89.0416
365  inside function 86.4618
second call vec2
364  inside function 0.0268704
363  inside function 0.0322394
365  inside function 0.0199141
2 nodes:
first call vec1
second call vec2
Many Thanks
Alice Raeli
Institut de Mathématiques de Bordeaux (IMB)
alice.raeli at math.u-bordeaux1.fr <mailto:alice.raeli at math.u-bordeaux1.fr>
alice.raeli at u-bordeaux.fr <mailto:alice.raeli at u-bordeaux.fr>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160524/70b165bc/attachment.html>
