[petsc-users] PetscDSSetResidual/PetscDSSetJacobian in fortran
Nestor Cerpa Gilvonio ncerpagi at umn.edu
Mon May 23 12:23:25 CDT 2016
Thank you for the response.
However, I am unsure what you mean by “to handle discretization themselves”. Would you recommend (or is it possible) to still use PetscFE/PetscQuadrature functions and then use this data to evaluate residual and jacobian using SNESSet…(), or is it better to just use our own pieces of code for all of this ?
Nestor
Postdoctoral researcher
Department of Earth Sciences
University of Minnesota
310 Pillsbury Drive SE
Minnepolis, MN 55455
E-mail : ncerpagi at umn.edu <mailto:ncerpagi at umn.edu>
> On May 22, 2016, at 7:06 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 22, 2016 at 2:08 AM, Nestor Cerpa <ncerpagi at umn.edu <mailto:ncerpagi at umn.edu>> wrote:
> Hello,
> I am trying to use PetscDSSetResidual and PetscDSSetJacobian in a simple fortran code but they seem to be missing in the include files (petsc-master). I get this error message :
> They are not there. Taking function pointers from Fortran is complex, and I do not understand the new
> framework that Jed put in place to do this. It is used, for example in SNESSetFunction(). I would be
> happy to integrate code if you have time to implement it, but right now I am pressed for time.
> Undefined symbols for architecture x86_64:
>   "_petscdssetresidual_", referenced from:
>       _MAIN__ in Poisson.o
> ld: symbol(s) not found for architecture x86_64
> collect2: error: ld returned 1 exit status
> make: [Poisson] Error 1 (ignored)
> /bin/rm -f -f Poisson.o
> I am also wondering if there are snes examples like ex12 or ex62 in fortran?
> Everyone using Plex in Fortran has so far preferred to handle the discretization themselves. I hope
> that changes, but as you note I will have to get the pointwise function support in there first.
>   Thanks,
>      Matt
> Thanks,
> Nestor
> Postdoctoral research associate
> E-mail : ncerpagi at umn.edu <mailto:cerpa003 at umn.edu>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160523/b57472b9/attachment.html>
