[petsc-users] problem during configuring
Satish Balay
balay at mcs.anl.gov
Thu May 12 14:04:32 CDT 2016
compilers: Check that C libraries can be used from Fortran
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
**** Configure header /tmp/petsc-9NYxlk/confdefs.h ****
configure.log is missing the log corresponding to the error encountered.
Usually this happens when the binaries cannot be run. One reason for that is - some of the .so files
couldn't be loaded by ld.so
You appear to have LD_LIBRARY_PATH set - so I'm not sure why you get this error.
Matt would have to check configure.log to see why the corresponding errors are mising from configure.log
Satish
On Wed, 11 May 2016, Seungbum Koo wrote:
> I am installing PETSc-3.7.0 on my new computer. The only thing that I
> installed after installing Ubuntu 16.04 is Intel compilers.
> While configuring, I faced with following error message.
> seungbum at asterix:~/install/petsc-3.7.0$ ./configure
> PETSC_DIR=/home/seungbum/install/petsc-3.7.0 PETSC_ARCH=arch-intel-debug
> --with-mpi-dir=/home/seungbum/install --with-debugging=1
> --with-debugger=gdb --with-blas-lapack-dir=/home/seungbum/intel/mkl
> --download-hdf5=yes --download-superlu=yes --download-superlu_dist=yes
> --download-metis=yes --download-parmetis=yes --download-scalapack=yes
> --download-mumps=yes
> Configuring PETSc to compile on your
> system
> TESTING: checkCLibraries from
> config.compilers(config/BuildSystem/config/compilers.py:168)
> UNABLE to EXECUTE BINARIES for ./configure
> Cannot run executables created with FC. If this machine uses a batch system
> to submit jobs you will need to configure using ./configure with the
> additional option --with-batch.
> Otherwise there is problem with the compilers. Can you compile and run
> code with your compiler '/home/seungbum/install/bin/mpif90'?
> See http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
> It is confusing because I already installed PETSc-3.7.0 on the workstation
> in my lab with exact same configure options without any problems.
> Can anyone help?
> Seungbum
