[petsc-users] petsc and slepc incompatibility
Dominic Steinitz dominic at steinitz.org
Sun May 8 03:35:24 CDT 2016
Reply to myself again, this seems to have worked:
Checkout the tag 3.6.3 on PETSc and build
Checkout the tag 3.6.3 on SLEPc and build
Sorry for the noise
Dominic.
On 08/05/2016 09:31, Dominic Steinitz wrote:
> Replying to myself
> I am not convinced what I am doing is going to work. I looked here:
> http://www.mcs.anl.gov/petsc/petsc-as/download/index.html and there is
> no mention of a 3.6.3 release despite there being a tag in the repo
> with 3.6.3.
> Can someone advise me which version of PETSc and SLEPc are compatible?
> Should I try PETSc 3.6.4 and SLEPc 3.6.3 or 3.6.0?
> Many thanks, Dominic.
> On 08/05/2016 09:22, Dominic Steinitz wrote:
>> Hi Karli,
>> Many thanks for the very swift reply :-) I did indeed look there and
>> it says
>>> Stay tuned via the mailing list
>> Which is why I subscribed to the slepc mailing list but perhaps it
>> meant *this* mailing list rather than the slepc mailing list?
>> I can build 3.7 :-) I have just checked out the tag marked 3.6.3 and
>> am trying to build that. I will report back soon.
>> Once again thanks for responding
>> Dominic.
>> On 08/05/2016 09:19, Karl Rupp wrote:
>>> Dear Dominic,
>>> have a look here:
>>> http://lists.mcs.anl.gov/pipermail/petsc-users/2016-April/029224.html
>>> Best regards,
>>> Karli
>>> On 05/08/2016 10:15 AM, Dominic Steinitz wrote:
>>>> Hi Hong,
>>>> I too am having compatibility issues. I looked at the git repos.
>>>>>   v3.7                       PETSc 3.7
>>>>>   v3.6.4                    PETSc 3.6.4
>>>>>   v3.6.3                    PETSc 3.6.3
>>>>>   v3.6.2                    PETSc 3.6.2
>>>>>   v3.6.1                    PETSc 3.6.1
>>>> and
>>>>>   v3.6.3                    SLEPc 3.6.3
>>>>>   v3.6.2                    SLEPc 3.6.2
>>>>>   v3.6.1                    SLEPc 3.6.1
>>>> If I just checkout master on both repos, won't I get PETSc 3.7 and
>>>> SLEPc
>>>> 3.6.3?
>>>> Should I checkout the tag for 3.6.3 on the PETSc repo?
>>>> BTW I checked https://listas.upv.es/pipermail/slepc-announce/ for
>>>> announcements on new versions but nothing has been posted since
>>>> June 2015.
>>>>> Marco:
>>>>> You may use petsc-master and slepc-master.
>>>>> Hong
>>>>> Dear All,
>>>>> >   first, let me congratulate and thank the PETSc team and all
>>>>> > contributors for release 3.7 .
>>>>> > I just noticed that the changes in Options handling introduced
>>>>> in 3.7
>>>>> > broke the build of the latest SLEPc (3.6.1, since 3.6.3 is
>>>>> flagged as
>>>>> > incompatible with 3.7).
>>>>> > Is there already a time estimate for a compatible release of
>>>>> SLEPc ?
>>>>> > Thank you and kind regards,
>>>>> > Marco Zocca
