[petsc-users] Crash in MatDuplicate_MPIAIJ_MatPtAP
Hong hzhang at mcs.anl.gov
Fri May 6 12:07:40 CDT 2016
Miorelli:
Fixed
https://bitbucket.org/petsc/petsc/commits/a560ef987c2a1e86047c71b5951614168aab22f9
After our regression tests, I'll merge it to petsc-release.
Thanks for report it!
Hong
Dear All,
> I think there may be a bug in PETSc 3.7.0, function
> MatDuplicate_MPIAIJ_MatPtAP.
> Whenever I call MatDuplicate on this type of matrix I'm getting SIGSEGV.
> The bug is easily reproduced with the attached file. This is just ex2f
> from KSP, where I added two additional lines to create an A^T A matrix
> which is then duplicated.
>       call MatTransposeMatMult(A, A, MAT_INITIAL_MATRIX, 1.d0, AtA, ierr)
>       call MatDuplicate(AtA,MAT_COPY_VALUES,AtA2,ierr)
> [1]PETSC ERROR:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [1]PETSC ERROR: likely location of problem given in stack below
> [1]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [1]PETSC ERROR: [1] MatDuplicate_MPIAIJ_MatPtAP line 78
> /state/std2/FEMI/PETSc/petsc-3.7.0/src/mat/impls/aij/mpi/mpiptap.c
> [1]PETSC ERROR: [1] MatDuplicate line 4324
> /state/std2/FEMI/PETSc/petsc-3.7.0/src/mat/interface/matrix.c
> Thanks,
> Federico
> *______* *______* *______*
> Federico Miorelli
> Senior R&D Geophysicist
> *Subsurface Imaging - General Geophysics **Italy*
> CGG Electromagnetics (Italy) Srl
> *This email and any accompanying attachments are confidential. If you
> received this email by mistake, please delete it from your system. Any
> review, disclosure, copying, distribution, or use of the email by others is
> strictly prohibited.*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160506/0c14a45f/attachment.html>
