[petsc-users] ISGetTotalIndices with Fortran
Thu Jun 30 12:20:44 CDT 2016
> On Jun 30, 2016, at 8:43 AM, Constantin Nguyen Van <constantin.nguyen.van at openmailbox.org> wrote:
> Hi again,
> I've noticed that the same error occurs with the subroutine MatGetRedundantMatrix.
> Is that possible to add the Fortran interface too?
   This one (it is MatCreateRedundantMatrix) actually can be created automatically but for some reason was turned off for automatic creation. I have fixed this in the maint branch. If you do a git pull on the maint branch (or master) and then make allfortranstubs it will generate the missing function for you.
    Thanks for letting us know
   Barry
> Thank you.
> Constantin.
> Le 2016-06-28 16:51, Constantin Nguyen Van a écrit :
>> Alright!
>> Thank you.
>> Constantin.
>> Le 2016-06-28 04:54, Barry Smith a écrit :
>>> I have added these fortran interfaces in the branch
>>> barry/add-missing-apis/maint and merged into the next branch for
>>> testing. When it passes the tests I will merge it into maint and it
>>> will then be available in the next patch release.
>>>   Barry
>>>> On Jun 27, 2016, at 7:50 AM, Constantin Nguyen Van <constantin.nguyen.van at openmailbox.org> wrote:
>>>> Hi,
>>>> I'm tring to use ISGetTotalIndices in a Fortran program but I've got an undefined reference error message when I compile it :"undefined reference to `isgettotalindices_'".
>>>> I've also tried to replace IsGetIndices by ISGetTotalIndices and also ISGetNonlocalIndices in this example http://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/is/examples/tutorials/ex1f.F.html but the same error occurs.
>>>> The "nm /lib/libpetsc.so |grep ISGetTotal" command returns "000000000031a7ab T ISGetTotalIndices" so that the symbol is there and nothing seems to be missing.
>>>> Are those routines available in Fortran?
>>>> Thank you.
>>>> Constantin.
