[petsc-users] da_overlap and zero pivot row
Xiangdong epscodes at gmail.com
Mon Jun 27 15:15:55 CDT 2016
Hello everyone,
I am trying different number of da_overlap to see its effects on nasm and
aspin preconditioner. The codes works fine with -da_overlap 0. However,
when I change the option -da_overlap 1, it crashed with the error message
like "zero pivot row 12544 value 0 tolerance 2.2e-14". The option
-pc_factor_nonzeros_along_diagonal does not fix this zero pivot issue.
Do you have any quick suggestions for me to try to fix this issue?
Thank you.
Best,
Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160627/43862ba0/attachment.html>
