[petsc-users] da_overlap and zero pivot row
Xiangdong epscodes at gmail.com
Wed Jun 29 10:49:40 CDT 2016
To make things easier, I created a simple example here:
https://drive.google.com/file/d/0BxEfb1tasJxhOHJWbVJ0ZGl0LTA/view?usp=sharing
./exe -snes_newtonls okay.
./exe -snes_nasm -da_grid_z 2 okay
./exe -snes_nasm failed. It got trapped in the while loop.
Do you have any suggestions to avoid this trap for nz=1?
Thanks.
Xiangdong
On Wed, Jun 29, 2016 at 11:23 AM, Xiangdong <epscodes at gmail.com> wrote:
> The code got trapped in a while loop when I switch to s=2.
> http://www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/da/dadd.c.html
> In dadd.c line 85-96
> /* gone out of processor range on y axis */
>  86:         while(jj > ne-1 || jj < ns) {
>  87:           if (nr == n-1) {
>  88:             ns = 0;
>  89:             ne = ly[0];
>  90:             nr = 0;
>  91:           } else {
>  92:             nr++;
>  93:             ns = ne;
>  94:             ne += ly[nr];
>  95:           }
>  96:         }
> For my case nx=5,ny=5,nz=1,s=2, np=2, snes_type nasm, the code is trapped
> in the loop for jj=-1, ns=0, nr=0, n=1. This negative jj comes from the
> line 340-349 of same file.
> /* global and subdomain ISes for the local indices of the subdomain */
> 341:     /* todo - make this not loop over at nonperiodic boundaries,
> which will be more involved */
> 342:     lower.i = subinfo.gxs;
> 343:     lower.j = subinfo.gys;
> 344:     lower.k = subinfo.gzs;
> 345:     upper.i = subinfo.gxs+subinfo.gxm;
> 346:     upper.j = subinfo.gys+subinfo.gym;
> 347:     upper.k = subinfo.gzs+subinfo.gzm;
> 349:     DMDACreatePatchIS(dm,&lower,&upper,&gdis);
> When trapped, subinfo.gxs=-2. Since there is a todo comment, I am not sure
> this is the reason for the while loop trap.
> Thanks.
> Xiangdong
> On Tue, Jun 28, 2016 at 5:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   If you make the stencil width as wide at the overlap does the problem
>> go away and you get expected convergence?
>> > On Jun 28, 2016, at 3:48 PM, Xiangdong <epscodes at gmail.com> wrote:
>> > Let me illustrate my point and question by an example. I have a 1d
>> nonlinear problem with Nx=5 and stencil width 1. When I run it with np=2,
>> processor 1 own cells 1,2,3 (+ ghost 4) and processor 2 own cells 4,5 (+
>> ghost 3). I also have functions FormFunctionLocal and FormJacobianLocal to
>> compute the residual and Jacobian.
>> > i) snes_type newtonls. The Jacobian is in mpiaij format distributed on
>> two processors. processor 1 computes the first three rows of Jac (size 3x5)
>> and processor 1 computes the last two rows of Jac (size 2x5). The code
>> works fine.
>> > ii) snes_type nasm and da_overlap 0. Each processor has its own Jac
>> (seqaij). Processor 1 computes its 3x3 Jac and Processor 2 computes its 2x2
>> Jac. The code works fine.
>> > iii) snes_type nasm and da_overlap 1. Each processor needs to computes
>> its own Jac. Processor 1 computes its 4x4 Jac and Processor 2 computes its
>> 3x3 Jac. However, for processor 1 to compute the 4-th row of its Jac, it
>> needs the properties information stored on cell 5, which is not available
>> on processor 1. The zero pivot error is from this wrong Jac for the row
>> corresponding to the overlap cell. The mat_fd_color does not work either
>> for the same reason that information from cell 5 is not available on
>> processor 1.
>> > Do you have any suggestion for the overlap case? Thank you.
>> > Best,
>> > Xiangdong
>> > On Mon, Jun 27, 2016 at 4:21 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > On Jun 27, 2016, at 3:15 PM, Xiangdong <epscodes at gmail.com> wrote:
>> > > Hello everyone,
>> > > I am trying different number of da_overlap to see its effects on nasm
>> and aspin preconditioner. The codes works fine with -da_overlap 0. However,
>> when I change the option -da_overlap 1, it crashed with the error message
>> like "zero pivot row 12544 value 0 tolerance 2.2e-14". The option
>> -pc_factor_nonzeros_along_diagonal does not fix this zero pivot issue.
>> > > Do you have any quick suggestions for me to try to fix this issue?
>> >    My guess is that it is bug in the da_overlap business or in the
>> example; normally I would not expect this to happen. Is this a PETSc
>> example I can run (tell me example and exact options) to reproduce the
>> problem?
>> >    Thanks
>> >    Barry
>> > > Thank you.
>> > > Best,
>> > > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160629/908c0149/attachment-0001.html>
