[petsc-users] da_overlap and zero pivot row
Xiangdong epscodes at gmail.com
Wed Jun 29 10:23:15 CDT 2016
The code got trapped in a while loop when I switch to s=2.
http://www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/da/dadd.c.html
In dadd.c line 85-96
/* gone out of processor range on y axis */
 86:         while(jj > ne-1 || jj < ns) {
 87:           if (nr == n-1) {
 88:             ns = 0;
 89:             ne = ly[0];
 90:             nr = 0;
 91:           } else {
 92:             nr++;
 93:             ns = ne;
 94:             ne += ly[nr];
 95:           }
 96:         }
For my case nx=5,ny=5,nz=1,s=2, np=2, snes_type nasm, the code is trapped
in the loop for jj=-1, ns=0, nr=0, n=1. This negative jj comes from the
line 340-349 of same file.
/* global and subdomain ISes for the local indices of the subdomain */
341:     /* todo - make this not loop over at nonperiodic boundaries, which
will be more involved */
342:     lower.i = subinfo.gxs;
343:     lower.j = subinfo.gys;
344:     lower.k = subinfo.gzs;
345:     upper.i = subinfo.gxs+subinfo.gxm;
346:     upper.j = subinfo.gys+subinfo.gym;
347:     upper.k = subinfo.gzs+subinfo.gzm;
349:     DMDACreatePatchIS(dm,&lower,&upper,&gdis);
When trapped, subinfo.gxs=-2. Since there is a todo comment, I am not sure
this is the reason for the while loop trap.
Thanks.
Xiangdong
On Tue, Jun 28, 2016 at 5:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   If you make the stencil width as wide at the overlap does the problem go
> away and you get expected convergence?
> > On Jun 28, 2016, at 3:48 PM, Xiangdong <epscodes at gmail.com> wrote:
> > Let me illustrate my point and question by an example. I have a 1d
> nonlinear problem with Nx=5 and stencil width 1. When I run it with np=2,
> processor 1 own cells 1,2,3 (+ ghost 4) and processor 2 own cells 4,5 (+
> ghost 3). I also have functions FormFunctionLocal and FormJacobianLocal to
> compute the residual and Jacobian.
> > i) snes_type newtonls. The Jacobian is in mpiaij format distributed on
> two processors. processor 1 computes the first three rows of Jac (size 3x5)
> and processor 1 computes the last two rows of Jac (size 2x5). The code
> works fine.
> > ii) snes_type nasm and da_overlap 0. Each processor has its own Jac
> (seqaij). Processor 1 computes its 3x3 Jac and Processor 2 computes its 2x2
> Jac. The code works fine.
> > iii) snes_type nasm and da_overlap 1. Each processor needs to computes
> its own Jac. Processor 1 computes its 4x4 Jac and Processor 2 computes its
> 3x3 Jac. However, for processor 1 to compute the 4-th row of its Jac, it
> needs the properties information stored on cell 5, which is not available
> on processor 1. The zero pivot error is from this wrong Jac for the row
> corresponding to the overlap cell. The mat_fd_color does not work either
> for the same reason that information from cell 5 is not available on
> processor 1.
> > Do you have any suggestion for the overlap case? Thank you.
> > Best,
> > Xiangdong
> > On Mon, Jun 27, 2016 at 4:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Jun 27, 2016, at 3:15 PM, Xiangdong <epscodes at gmail.com> wrote:
> > > Hello everyone,
> > > I am trying different number of da_overlap to see its effects on nasm
> and aspin preconditioner. The codes works fine with -da_overlap 0. However,
> when I change the option -da_overlap 1, it crashed with the error message
> like "zero pivot row 12544 value 0 tolerance 2.2e-14". The option
> -pc_factor_nonzeros_along_diagonal does not fix this zero pivot issue.
> > > Do you have any quick suggestions for me to try to fix this issue?
> >    My guess is that it is bug in the da_overlap business or in the
> example; normally I would not expect this to happen. Is this a PETSc
> example I can run (tell me example and exact options) to reproduce the
> problem?
> >    Thanks
> >    Barry
> > > Thank you.
> > > Best,
> > > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160629/661fbdd4/attachment.html>
