[petsc-users] On the edge of 2^31 unknowns
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Tue Jun 21 15:20:24 CDT 2016
Hi Hong,
thanks... but I just realized, that into petsc 3.5.4 (which I used for
this calculus) the default *was* the scalable version... :/
So I prepared a patch (see attachment) to help debug, but it will be
based on 3.7.2. We may use it to extract information to do a better bug
report. Do you think there is enough PetscInfo added to resolve this issue?
What else would you add?
Eric
On 21/06/16 09:36 AM, hong at aspiritech.org wrote:
> Eric:
> The nonscalable implementation is robust, and faster for small to medium
> size problems, thus we set it as the default. You can switch with option
> '-matmatmult_via scalable', which requires estimate of nonzeros A*B.
> The estimate was buggy, not well-tested. If you encounter any problem,
> let us know.
> Hong
> On Mon, Jun 20, 2016 at 10:49 PM, Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
> Le 2016-06-20 23:37, Barry Smith a écrit :
> On Jun 20, 2016, at 10:32 PM, Eric Chamberland
> ok, but what about -matmatmult_via scalable?
> Both should work. It just may be one is faster or slower
> than the other depending on the problem size.
> ok, digging further, I found this into blaming the code:
> 0fc8cf34 (Hong Zhang 2013-06-27 14:04:58 -0500 696) /* same
> as MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable(), except using
> LLCondensed to avoid O(BN) memory requirement */
> But the commit comment says:
> rename MatMatMultSymbolic_MPIAIJ_MPIAIJ ->
> MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (non-default)
> But it *is* the default... since another commit:
> commit 0d3441ae8a080c728abf17e90308c510e39e951b
> Author: Hong Zhang <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>>
> Date: Mon Aug 24 16:40:35 2015 -0500
> add MatPtAPxxx_MPIAIJ_MPIAIJ_new
> which changed the behaviour programmed in 0fc8cf34. Is it normal?
> Eric
commit a965ae203520bf228c3e87d1afcbac679da3e65a
Author: Eric Chamberland <ericc at giref.ulaval.ca>
Date: Mon Jun 20 14:24:53 2016 -0400
DBG: Info pour matmatmult
diff --git a/src/mat/impls/aij/mpi/mpimatmatmult.c b/src/mat/impls/aij/mpi/mpimatmatmult.c
index 816b735..6a81b70 100644
--- a/src/mat/impls/aij/mpi/mpimatmatmult.c
+++ b/src/mat/impls/aij/mpi/mpimatmatmult.c
@@ -212,12 +212,15 @@ PetscErrorCode MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable(Mat A,Mat P,PetscRea
/* first, compute symbolic AP = A_loc*P = A_diag*P_loc + A_off*P_oth */
+ ierr = PetscInfo1(A,"MatMatMultSymns_mpi_mpi: PetscMalloc1 am+2 %d;\n",am+2);CHKERRQ(ierr);
+ printf("COUCOU DANS MATMATMULTMPINS\n");
ierr = PetscMalloc1(am+2,&api);CHKERRQ(ierr);
ptap->api = api;
api[0] = 0;
/* create and initialize a linked list */
- ierr = PetscTableCreate(pN,pN,&ta);CHKERRQ(ierr);
+ ierr = PetscInfo1(A,"MatMatMultSymns_mpi_mpi: PetscTableCreate pN %d;\n",pN);CHKERRQ(ierr);
+ ierr = PetscTableCreate(pN,pN,&ta);CHKERRQ(ierr);
MatRowMergeMax_SeqAIJ(p_loc,ptap->P_loc->rmap->N,ta);
MatRowMergeMax_SeqAIJ(p_oth,ptap->P_oth->rmap->N,ta);
ierr = PetscTableGetCount(ta,&Crmax);CHKERRQ(ierr);
@@ -226,6 +229,11 @@ PetscErrorCode MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable(Mat A,Mat P,PetscRea
ierr = PetscLLCondensedCreate(Crmax,pN,&lnk,&lnkbt);CHKERRQ(ierr);
/* Initial FreeSpace size is fill*(nnz(A)+nnz(P)) */
+ ierr = PetscInfo1(A,"MatMatMultSymns_mpi_mpi: fill %g;\n",fill);CHKERRQ(ierr);
+ PetscInt lnnz = PetscIntSumTruncate(adi[am],PetscIntSumTruncate(aoi[am],pi_loc[pm]));
+ ierr = PetscInfo1(A,"MatMatMultSymns_mpi_mpi: lnnz %g;\n",lnnz);CHKERRQ(ierr);
+ PetscInt lMem = PetscRealIntMultTruncate(fill,PetscIntSumTruncate(adi[am],PetscIntSumTruncate(aoi[am],pi_loc[pm])));
+ ierr = PetscInfo1(A,"MatMatMultSymns_mpi_mpi: lMem %g;\n",lMem);CHKERRQ(ierr);
ierr = PetscFreeSpaceGet(PetscRealIntMultTruncate(fill,PetscIntSumTruncate(adi[am],PetscIntSumTruncate(aoi[am],pi_loc[pm]))),&free_space);CHKERRQ(ierr);
current_space = free_space;
@@ -733,6 +741,8 @@ PetscErrorCode MatMatMultSymbolic_MPIAIJ_MPIAIJ(Mat A,Mat P,PetscReal fill,Mat *
+ ierr = PetscInfo1(A,"MatMatMultSym_mpi_mpi: PetscMalloc1 am+2 %d;\n",am+2);CHKERRQ(ierr);
+ printf("COUCOU DANS MATMATMULTMPI\n");
ptap->api = api;
api[0] = 0;
@@ -740,7 +750,9 @@ PetscErrorCode MatMatMultSymbolic_MPIAIJ_MPIAIJ(Mat A,Mat P,PetscReal fill,Mat *
apnz_max = 6*(p_loc->rmax + (PetscInt)(1.e-2*pN)); /* expected apnz_max */
if (apnz_max > pN) apnz_max = pN;
- ierr = PetscTableCreate(apnz_max,pN,&ta);CHKERRQ(ierr);
+ ierr = PetscInfo1(A,"MatMatMultSym_mpi_mpi: PetscTableCreate am+2 %d;\n",apnz_max);CHKERRQ(ierr);
+ ierr = PetscInfo1(A,"MatMatMultSym_mpi_mpi: PetscTableCreate pN %d;\n",pN);CHKERRQ(ierr);
+ ierr = PetscTableCreate(apnz_max,pN,&ta);CHKERRQ(ierr);
/* Calculate apnz_max */
apnz_max = 0;
@@ -765,6 +777,12 @@ PetscErrorCode MatMatMultSymbolic_MPIAIJ_MPIAIJ(Mat A,Mat P,PetscReal fill,Mat *
ierr = PetscLLCondensedCreate_Scalable(apnz_max,&lnk);CHKERRQ(ierr);
+ ierr = PetscInfo1(A,"MatMatMultSym_mpi_mpi: fill %g;\n",fill);CHKERRQ(ierr);
+ ierr = PetscInfo1(A,"MatMatMultSym_mpi_mpi: lnnz %g;\n",lnnz);CHKERRQ(ierr);
+ ierr = PetscInfo1(A,"MatMatMultSym_mpi_mpi: lMem %g;\n",lMem);CHKERRQ(ierr);
ierr = MatPreallocateInitialize(comm,am,pn,dnz,onz);CHKERRQ(ierr);
