[petsc-users] On the edge of 2^31 unknowns
hong at aspiritech.org
Tue Jun 21 08:36:07 CDT 2016
Eric:
The nonscalable implementation is robust, and faster for small to medium
size problems, thus we set it as the default. You can switch with
option '-matmatmult_via
scalable', which requires estimate of nonzeros A*B.
The estimate was buggy, not well-tested. If you encounter any problem, let
us know.
Hong
On Mon, Jun 20, 2016 at 10:49 PM, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Le 2016-06-20 23:37, Barry Smith a écrit :
>> On Jun 20, 2016, at 10:32 PM, Eric Chamberland <
>>> ok, but what about -matmatmult_via scalable?
>> Both should work. It just may be one is faster or slower than the
>> other depending on the problem size.
> ok, digging further, I found this into blaming the code:
> 0fc8cf34 (Hong Zhang 2013-06-27 14:04:58 -0500 696) /* same as
> MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable(), except using LLCondensed to
> avoid O(BN) memory requirement */
> But the commit comment says:
> rename MatMatMultSymbolic_MPIAIJ_MPIAIJ ->
> MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (non-default)
> But it *is* the default... since another commit:
> commit 0d3441ae8a080c728abf17e90308c510e39e951b
> Author: Hong Zhang <hzhang at mcs.anl.gov>
> Date: Mon Aug 24 16:40:35 2015 -0500
> add MatPtAPxxx_MPIAIJ_MPIAIJ_new
> which changed the behaviour programmed in 0fc8cf34. Is it normal?
> Eric
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160621/b6d285ca/attachment.html>
