[petsc-users] Trouble installing PETSc on a supercomputer
namu patel
namu.patel7 at gmail.com
Mon Jun 20 19:47:00 CDT 2016
Hello All,
I am trying to PETSc 3.5.4 XSEDE Bridges. After running configure command:
./config/configure.py --CC=mpicc --CXX=mpicxx --FC=mpif90
known-mpi-shared-libraries=1 --PETSC_ARCH=$PETSC_ARCH
--with-shared-libraries --with-debugging=0 --with-x=0 --download-hypre=1
--download-sundials=1 --download-fblaslapack=1 --with-batch
the library prompts me to do as follows:
Since your compute nodes require use of a batch system or mpiexec you
must:
1) Submit ./conftest-linux-opt to 1 processor of your batch system or
system you are
cross-compiling for; this will generate the file reconfigure.py
2) Run ./reconfigure-linux-opt.py (to complete the configure process).
I submitted the executable ./conftest-linux-opt to the queue using a
single process. I expected this script to only run for a few minutes and
generate the ./reconfigure-linux-opt.py file, however, it had been running
hours without generating the script (and I just terminated the job at that
point). I feel like I'm doing something wrong. Does anyone have any
suggestions on where I may have gone wrong?
Thank you,
Namu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160620/92490249/attachment-0001.html>
