[petsc-users] Problem with interpolating projected field of quadratic order
Sat Jun 18 09:26:40 CDT 2016
On Sat, Jun 18, 2016 at 8:56 AM, Sander Arens <Sander.Arens at ugent.be> wrote:
> Hello all,
> Recently I've been trying to run a fem problem using DMPlex, PetscFE, etc.
> using a mesh created with gmsh. I used DMPlexReverseCell to get rid of the
> negative jacobian determinants. However, I noticed another problem: when I
> projected the coordinates on a quadratic fem-field and interpolated them
> they didn't match the interpolated values of the original coordinate field
> anymore.
> I attached a simple test to reproduce this. With linear interpolation I
> see no problem, it's only when I start using quadratic interpolation.
> I have no idea why this is giving problems. Am I missing something simple
> here or is this a bug?
Tests for this already exist
https://bitbucket.org/petsc/petsc/src/996a00f1a1693e2d85044ed633fe1848cf357f2a/src/dm/impls/plex/examples/tests/ex3.c?at=master&fileviewer=file-view-default
with run parameters here:
https://bitbucket.org/petsc/petsc/src/996a00f1a1693e2d85044ed633fe1848cf357f2a/config/builder.py?at=master&fileviewer=file-view-default#builder.py-58
and specifically for P2 triangles
https://bitbucket.org/petsc/petsc/src/996a00f1a1693e2d85044ed633fe1848cf357f2a/config/builder.py?at=master&fileviewer=file-view-default#builder.py-72
1) Does the test run for you?
  ./config/builder2.py check src/dm/impls/plex/examples/tests/ex3.c
2) If so, then could it be that you assume something about the order of
functions?
     Matt
> Thanks,
> Sander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160618/829e8e81/attachment.html>
