[petsc-users] Problem with interpolating projected field of quadratic order
Sander Arens
Sander.Arens at ugent.be
Sat Jun 18 08:56:05 CDT 2016
Hello all,
Recently I've been trying to run a fem problem using DMPlex, PetscFE, etc.
using a mesh created with gmsh. I used DMPlexReverseCell to get rid of the
negative jacobian determinants. However, I noticed another problem: when I
projected the coordinates on a quadratic fem-field and interpolated them
they didn't match the interpolated values of the original coordinate field
anymore.
I attached a simple test to reproduce this. With linear interpolation I see
no problem, it's only when I start using quadratic interpolation.
I have no idea why this is giving problems. Am I missing something simple
here or is this a bug?
Sander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160618/11db7a91/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160618/11db7a91/attachment-0001.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160618/11db7a91/attachment-0001.obj>
