[petsc-users] Vec application ordering to petsc ordering
Santiago Ospina De Los Rios
sospinar at unal.edu.co
Sun Jun 12 02:20:04 CDT 2016
2016-06-12 2:14 GMT-05:00 Santiago Ospina De Los Rios <sospinar at unal.edu.co>
> 2016-06-12 2:02 GMT-05:00 Matthew Knepley <knepley at gmail.com>:
>> On Sun, Jun 12, 2016 at 7:49 AM, Santiago Ospina De Los Rios <
>> sospinar at unal.edu.co> wrote:
>>> Hello there,
>>> I'm using your Application Ordering (AO) objects to switch between
>>> vectors with my application ordering to petsc ordering. I built a little
>>> routine which helps me to gather the information in the proper order:
>>> SUBROUTINE VecApplicationToPetsc(DataMngr,AppVec,ierr)
>>> IMPLICIT NONE
>>> #include <petsc/finclude/petscsys.h>
>>> #include <petsc/finclude/petscvec.h>
>>> #include <petsc/finclude/petscis.h>
>>> #include <petsc/finclude/petscdm.h>
>>> #include <petsc/finclude/petscdmda.h>
>>> #include <petsc/finclude/petscao.h>
>>> PetscErrorCode,INTENT(INOUT) :: ierr
>>> DM,INTENT(IN) :: DataMngr
>>> Vec,INTENT(INOUT) :: AppVec ! it outs as PetscVec
>>> AO :: AppOrd
>>> PetscInt :: RangeLow,RangeHigh,i
>>> IS :: PetscIS,AppIS
>>> VecScatter :: Scatter
>>> Vec :: PetscVec
>>> ! It obtains a temporal vector to store in PETSc ordering
>>> CALL DMCreateGlobalVector(DataMngr,PetscVec,ierr)
>>> CALL AOCreate(PETSC_COMM_WORLD,AppOrd,ierr)
>> Here you create a new AO object
>>> CALL DMDAGetAO(DataMngr,AppOrd,ierr)
>> Here you overwrite that initial AO with the AO from the DMDA, thus
>> leaking memory.
>>> CALL VecGetOwnershipRange(PetscVec,RangeLow,RangeHigh,ierr)
>>> CALL
>>> ISCreateGeneral(PETSC_COMM_WORLD,RangeHigh-RangeLow,(/(i,i=RangeLow,RangeHigh)/),PETSC_COPY_VALUES,PetscIS,ierr)
>>> CALL ISDuplicate(PetscIS,AppIS,ierr)
>>> CALL ISCopy(PetscIS,AppIS,ierr)
>>> CALL AOPetscToApplicationIS(AppOrd,AppIS,ierr)
>>> CALL VecScatterCreate(AppVec,AppIS,PetscVec,PetscIS,Scatter,ierr)
>>> CALL
>>> VecScatterBegin(Scatter,AppVec,PetscVec,INSERT_VALUES,SCATTER_FORWARD,ierr)
>>> CALL
>>> VecScatterEnd(Scatter,AppVec,PetscVec,INSERT_VALUES,SCATTER_FORWARD,ierr)
>>> CALL VecScatterDestroy(Scatter,ierr)
>>> CALL ISDestroy(AppIS,ierr)
>>> CALL ISDestroy(PetscIS,ierr)
>>> CALL AODestroy(AppOrd,ierr)
>> Here you destroy the DMDA AO, which causes the error, but not the
>> original AO, which causes a leak.
>> Remove the Create/Destroy.
> It worked pretty well, thank you.
> But what do you mean with "original AO"? is it not supposed one have to
> destroy every petsc object created?
> Forget it, I already understand.
> Santiago O.
> Matt
>>> CALL VecCopy(PetscVec,AppVec,ierr)
>>> CALL VecDestroy(PetscVec,ierr)
>>> END SUBROUTINE VecApplicationToPetsc
>>> It is working well for my purpose, but just the first time I call it;
>>> the second time I call it, the AO object give me back an error. The most
>>> obviously way to avoid it is creating AO, IS and VecScatter objects just
>>> one time, but I don't want to handle those variables through my whole
>>> program.
>>> Am I doing something wrong with the AO object?
>>> Thank you.
>>> Att:
>>> Santiago Ospina De Los Ríos
>>> National University of Colombia
>> experiments lead.
>> -- Norbert Wiener
> Att:
Att:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160612/9a152574/attachment.html>
