[petsc-users] Vec application ordering to petsc ordering
Santiago Ospina De Los Rios
sospinar at unal.edu.co
Sun Jun 12 02:14:53 CDT 2016
2016-06-12 2:02 GMT-05:00 Matthew Knepley <knepley at gmail.com>:
> On Sun, Jun 12, 2016 at 7:49 AM, Santiago Ospina De Los Rios <
> sospinar at unal.edu.co> wrote:
>> Hello there,
>> I'm using your Application Ordering (AO) objects to switch between
>> vectors with my application ordering to petsc ordering. I built a little
>> routine which helps me to gather the information in the proper order:
>> SUBROUTINE VecApplicationToPetsc(DataMngr,AppVec,ierr)
>> IMPLICIT NONE
>> #include <petsc/finclude/petscsys.h>
>> #include <petsc/finclude/petscvec.h>
>> #include <petsc/finclude/petscis.h>
>> #include <petsc/finclude/petscdm.h>
>> #include <petsc/finclude/petscdmda.h>
>> #include <petsc/finclude/petscao.h>
>> PetscErrorCode,INTENT(INOUT) :: ierr
>> DM,INTENT(IN) :: DataMngr
>> Vec,INTENT(INOUT) :: AppVec ! it outs as PetscVec
>> AO :: AppOrd
>> PetscInt :: RangeLow,RangeHigh,i
>> IS :: PetscIS,AppIS
>> VecScatter :: Scatter
>> Vec :: PetscVec
>> ! It obtains a temporal vector to store in PETSc ordering
>> CALL DMCreateGlobalVector(DataMngr,PetscVec,ierr)
>> CALL AOCreate(PETSC_COMM_WORLD,AppOrd,ierr)
> Here you create a new AO object
>> CALL DMDAGetAO(DataMngr,AppOrd,ierr)
> Here you overwrite that initial AO with the AO from the DMDA, thus leaking
> memory.
>> CALL VecGetOwnershipRange(PetscVec,RangeLow,RangeHigh,ierr)
>> CALL
>> ISCreateGeneral(PETSC_COMM_WORLD,RangeHigh-RangeLow,(/(i,i=RangeLow,RangeHigh)/),PETSC_COPY_VALUES,PetscIS,ierr)
>> CALL ISDuplicate(PetscIS,AppIS,ierr)
>> CALL ISCopy(PetscIS,AppIS,ierr)
>> CALL AOPetscToApplicationIS(AppOrd,AppIS,ierr)
>> CALL VecScatterCreate(AppVec,AppIS,PetscVec,PetscIS,Scatter,ierr)
>> CALL
>> VecScatterBegin(Scatter,AppVec,PetscVec,INSERT_VALUES,SCATTER_FORWARD,ierr)
>> CALL
>> VecScatterEnd(Scatter,AppVec,PetscVec,INSERT_VALUES,SCATTER_FORWARD,ierr)
>> CALL VecScatterDestroy(Scatter,ierr)
>> CALL ISDestroy(AppIS,ierr)
>> CALL ISDestroy(PetscIS,ierr)
>> CALL AODestroy(AppOrd,ierr)
> Here you destroy the DMDA AO, which causes the error, but not the original
> AO, which causes a leak.
> Remove the Create/Destroy.
It worked pretty well, thank you.
But what do you mean with "original AO"? is it not supposed one have to
destroy every petsc object created?
Santiago O.
Matt
>> CALL VecCopy(PetscVec,AppVec,ierr)
>> CALL VecDestroy(PetscVec,ierr)
>> END SUBROUTINE VecApplicationToPetsc
>> It is working well for my purpose, but just the first time I call it; the
>> second time I call it, the AO object give me back an error. The most
>> obviously way to avoid it is creating AO, IS and VecScatter objects just
>> one time, but I don't want to handle those variables through my whole
>> program.
>> Am I doing something wrong with the AO object?
>> Thank you.
>> Att:
>> Santiago Ospina De Los Ríos
>> National University of Colombia
> experiments lead.
> -- Norbert Wiener
Att:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160612/63b7c368/attachment-0001.html>
