[petsc-users] KSPSolve errors on blues
Barry Smith
bsmith at mcs.anl.gov
Wed Jun 8 11:51:02 CDT 2016
Signal 9 SIGKILL on batch systems usually means the process was killed because it ran out of time or ran out of memory.
Perhaps there is something in the code that is unscalable and requires more more memory with more processes. You can run on 1 2 and 3 processes and measure the memory usage to see if it goes up with the number of processes using for example -memory_view
Barry
> On Jun 8, 2016, at 11:41 AM, Xujun Zhao <xzhao99 at gmail.com> wrote:
> Hi all,
> I am running a FE Stokes Solver with schur complement type PC on blues. The program runs well when mesh is 40X40X40 (0.88M dofs), but when I use 60X60X60 mesh, the program crashes and gives out some errors, which looks like a segmentation fault. The "strange" thing is that it runs well with 1CPU, 2CPUs, but fails on 4 or 8 CPUs. The log files are also attached. It seems like the global matrix and vector are assembled well, and errors come out before calling the KSPSolve().
> btw, I use the recent PETSc 3.7 dbg version. for libMesh I use both dbg and opt version, but none of those can give useful information. Has anyone met such situations before? Many thinks.
> <ex01_validation_test.o1386940><ex01_validation_test.o1387007>
