[petsc-users] TSSetExactFinalTime Behavior Without TSAdapt
Paul Urbanczyk
gomer at stanford.edu
Tue Jun 7 14:49:33 CDT 2016
Hello,
See below for my initial code, before adding TSSetExactFinalTime.
That version yielded the following error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: You must call TSSetExactFinalTime() or use
-ts_exact_final_time <stepover,interpolate,matchstep> before calling
TSSolve()
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.1-449-g419beca GIT
Date: 2016-06-01 15:39:33 -0500
[0]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by
gomer Tue Jun 7 12:42:05 2016
[0]PETSC ERROR: Configure options
[0]PETSC ERROR: #1 TSSolve() line 3946 in
/home/gomer/local/petsc/src/ts/interface/ts.c
I then added:
TSSetExactFinalTime(ts_solver,TS_EXACTFINALTIME_STEPOVER);
Running then yielded the following error:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] TSAdaptChoose line 571
/home/gomer/local/petsc/src/ts/adapt/interface/tsadapt.c
[0]PETSC ERROR: [0] TSStep_Euler line 20
/home/gomer/local/petsc/src/ts/impls/explicit/euler/euler.c
[0]PETSC ERROR: [0] TSStep line 3707
[0]PETSC ERROR: [0] TSSolve line 3928
[0]PETSC ERROR: Signal received
gomer Tue Jun 7 12:44:17 2016
[0]PETSC ERROR: #1 User provided function() line 0 in unknown file
Finally, I added
TSAdapt ts_adapt;
TSGetAdapt(ts_solver,&ts_adapt);
TSAdaptSetType(ts_adapt,TSADAPTNONE);
After adding this, the program runs without error.
Hope that helps.
Please let me know if I was doing something wrong before to have caused
this. It's not pressing for me, though, as my code now appears to be
running ok.
-Paul
ORIGINAL VERSION WITHOUT TSSetExactFinalTime:
void cPETScSolverClass::SolveTSProblem()
if(mpi_main.getRank() == 0)
std::cout << "*****STARTING SOLUTION*****" << std::endl;
// Set up the time-stepping solver object
TSCreate(PETSC_COMM_WORLD,&ts_solver);
// Set the problem type to be nonlinear
TSSetProblemType(ts_solver,TS_NONLINEAR);
// Point the solution to the solution vector (vector of conserved
variables)
TSSetSolution(ts_solver,solver_main.U_cons);
// Set the time-stepping type
TSSetType(ts_solver,TSEULER);
// Set the initial time and the time step
TSSetInitialTimeStep(ts_solver,0.0,0.001);
// Set the total duration (number of steps and total time)
TSSetDuration(ts_solver,10,0.01);
// Point the solver to the monitor function
TSMonitorSet(ts_solver,solver_main.TS_Monitor,this,NULL);
// Set the distributed array context for the solver
TSSetDM(ts_solver,main_da);
// Get the nonlinear solver for the time-stepping solver
TSGetSNES(ts_solver,&nl_solver);
// Write out the initial condition before the solver is started
WriteSolutionCSV("initial_condition.csv");
// Run the solver!
TSSolve(ts_solver,solver_main.U_cons);
std::cout << "-----COMPLETED SOLUTION-----" << std::endl;
// Write out the solution at the end
WriteSolutionCSV("output_test.csv");
// Destroy the time-stepping solver
TSDestroy(&ts_solver);
NEW VERSION WITH TSSetExactFinalTime and TSAdaptSetType:
variables)
TSSetDuration(ts_solver,1,0.001);
// Set TS exact final time behavior
// Set TS adaptive time stepping behavior
TSAdapt ts_adapt;
// Point the solver to the function which evaluates the right hand side
TSSetRHSFunction(ts_solver,solver_main.RHS,solver_main.FormFunction,this);
// Run the solver!
On 06/05/2016 06:44 PM, Barry Smith wrote:
> Paul,
> I don't think this was an expected change. Can you send code or walk us through the steps that led you to this?
> Barry
>> On Jun 3, 2016, at 10:23 AM, Paul Urbanczyk <gomer at stanford.edu> wrote:
>> Hello,
>> I recently upgraded to the latest version of PETSc (3.7.1) from the git repository.
>> Running my code gave me an error message about TSSolve being in the wrong state and needing to call TSSetExactFinalTime.
>> I added this function call with TS_EXACTFINALTIME_STEPOVER, but when I re-ran my code, I got a seg fault and error messages pointing to TSAdaptChoose.
>> After fiddling around for a while, I found that I now needed to explicitly set the time step adaptation through TSAdaptSetType.
>> Can anyone confirm that this is so? If so, it might be helpful to note that in documentation or error messages somewhere.
>> Thanks,
>> Paul
