[petsc-users] How to refine the Vertex Sets in DMPlex
Tue Jun 7 09:06:11 CDT 2016
On Tue, Jun 7, 2016 at 3:05 PM, Rongliang Chen <rl.chen at siat.ac.cn> wrote:
> Hi Matt,
> Thanks for your reply.
> Yes, I only labels the vertex because I am doing the finite element method
> where I only need the vertex label. Do you mean that I need to label the
> faces and get the vertex label from the  face label?
You need to label vertices and edges.
    Matt
> Thanks,
> Rongliang
> On 06/07/2016 09:51 PM, Matthew Knepley wrote:
> On Tue, Jun 7, 2016 at 10:09 AM, Rongliang Chen <rl.chen at siat.ac.cn>
> wrote:
>> Dear All,
>> I am using the DMRefine_Plex to refine a mesh. In the coarse mesh, it has
>> a label "Vertex Sets" to mark the boundary nodes. I found that the
>> DMRefine_Plex did not refine this label.
>> For example, in the coarse mesh, there are 100 nodes on the boundary,
>> that is the number of nodes in the label is 100. In the refined mesh
>> (uniformly refined), the number of nodes in the label should be larger than
>> 100, but I found that this number is still 100, which means the newly added
>> nodes on the boundary were not added to the label.
>> But I need a refined label to set the boundary conditions. Anyone can
>> tell me how to get a refined Vertex Sets label?
> All operations are topological in Plex, not geometric. When we refine, we
> split edges (for instance) and the new vertex inserted
> inherits the labels from the edge that was split. I am guessing that you
> only labels the vertices.
>   Thanks,
>     Matt
>> Best regards,
>> Rongliang
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160607/fea3de07/attachment.html>
