[petsc-users] Clarification on PCASMSetLocalSubdomain is and is_local
Matthew Knepley
knepley at gmail.com
Thu Jun 2 17:21:44 CDT 2016
On Thu, Jun 2, 2016 at 5:11 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>
wrote:
> Hi all,
> I would like a quick clarification on what is and is_local are
> representing in the PCASMSetLocalSubdomains().
> My understanding is that if I have two mpi ranks and four subdomains I can
> end up having four blocks that I can denote as follows:
> | domain1 | domain2 | domain3 | domain3 |
> rank1 | block11 | block12 | block13 | |
> rank2 | block21 | block22 | -- | block24 |
> to each blockIJ I associate isIJ.
> So for rank1 I will have is=[1,2,3] and is_local=[is11,is12,is13], and for
> rank2 I will have is=[1,2,4] and is_local=[is21,is22,is24].
> Or am I not understanding things correctly?
I did not understand the above.
The best way to think of this is algebraically. Suppose you have a matrix
A, and you divide the rows into k disjoint sets where each
process gets one set. Then is_local on each process is a list of the rows
in that set. Now we also allow some overlap, which means
rows in other sets are also used. The is on each process contains both
is_local and these extra rows from other sets.
Matt
> Best,
> Luc
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160602/b2472228/attachment.html>
