[petsc-users] Editor for PETSc
Jed Brown
jed at jedbrown.org
Fri Feb 5 10:06:43 CST 2016
Kaushik Kulkarni <kaushikggg at gmail.com> writes:
> The problem is not exactly with VIM. It is the plugins, I am using which
> gives me suggestions( or the auto-complete feature ) as well as checks the
> syntax. But, as it can be seen in the image attached it keeps on popping an
> error.
> The thing would be mostly to provide the correct flags to the plugin, which
> currently is :
> *===============================================================flags =
> [ '-Wall', '-std=c++11', '-stdlib=libc++', '-x', 'c++',
> '-I',
> Is there anyway, I could modify it so that my problem is solved.
-I$PETSC_DIR/include -I$PETSC_DIR/$PETSC_ARCH/include
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/c229f301/attachment.pgp>
