[petsc-users] Editor for PETSc
Kaushik Kulkarni
kaushikggg at gmail.com
Fri Feb 5 08:14:53 CST 2016
The problem is not exactly with VIM. It is the plugins, I am using which
gives me suggestions( or the auto-complete feature ) as well as checks the
syntax. But, as it can be seen in the image attached it keeps on popping an
error.
The thing would be mostly to provide the correct flags to the plugin, which
currently is :
*===============================================================flags =
[ '-Wall', '-std=c++11', '-stdlib=libc++', '-x', 'c++',
'-I',
Is there anyway, I could modify it so that my problem is solved.
Kaushik
On Fri, Feb 5, 2016 at 2:36 PM, Timothée Nicolas <timothee.nicolas at gmail.com
> wrote:
> Hi,
> You don't really specify your problem with this editor, do you ? But in
> any case, why not try emacs ? As you can see in the FAQ, this is what they
> use to develop it :
> http://www.mcs.anl.gov/petsc/documentation/faq.html
> Best
> Timothee
> 2016-02-05 17:57 GMT+09:00 Kaushik Kulkarni <kaushikggg at gmail.com>:
>> Hello,
>> I am a newbie to PETSc. I am going thorugh the tutorials right now. But I
>> am struggling a bit in finding the correct editor for me. Till now I was
>> fine with VIM, as it gave me a bunch of completions options in the form of
>> a drop down box. And using the Clang support feature it would also
>> highlight the errors hence drastically decreasing my errors. Is there any
>> way I could continue working on such environment.
>> I was using the "YouCompleteMe" plugin with VIM which had all of these
>> features.
>> Thanks,
>> *Kaushik*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/32eb0ab1/attachment-0001.html>
Name: Screenshot from 2016-02-05 14:05:58.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/32eb0ab1/attachment-0001.png>
