[petsc-users] Problem with "If the actual argument is scalar, the dummy argument shall be scalar unless the actual argument is of type charac..."
Tue Dec 27 11:17:08 CST 2016
Looks like this issue was previously discussed
http://lists.mcs.anl.gov/pipermail/petsc-users/2015-October/027365.html
Satish
On Tue, 27 Dec 2016, Zhang, Hong wrote:
> PetscInt   IIA(1)
> IIA(1) = II
> call MatSetValues(A_mat_uv,1,IIA,1,int_impl(k,3),impl_mat_A,INSERT_VALUES,ierr)
> Hong (Mr)
> > On Dec 27, 2016, at 2:38 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> > Hi,
> > I'm now trying to compile an old code and I got the error:
> > which happens at:
> > call MatSetValues(A_mat_uv,1,II,1,int_impl(k,3),impl_mat_A,INSERT_VALUES,ierr)
> > I remember having this error. However, I can't find my solution. I recall it's due to some changes in the new PETSc version.
> > Can you help?
> > Thank you
> > Yours sincerely,
> > TAY wee-beng
