[petsc-users] traceback & error handling
Satish Balay
balay at mcs.anl.gov
Mon Dec 19 16:09:17 CST 2016
PETSc code doesn't use classes - so we don't see this isssue.
One way to fix this is:
#undef #undef __FUNCT__
#if (__INTEL_COMPILER)
#define __FUNCT__ “ClassName::FunctionName”
#else
#define __FUNCT__ “FunctionName”
#endif
Alternative is to not do this check For compiles that define __func__
[like intel, gcc] __FUNCT__ is not used anyway. So perhaps the following
will work? [without having to modify petsc include files]
#undef PetscCheck__FUNCT__
#define PetscCheck__FUNCT__()
Wrt CHKERRQ() - which code are you refering to?
Satish
On Mon, 19 Dec 2016, Andreas Mang wrote:
> Hey guys:
> I have some problems with the error handling. On my local machine (where I debug) I get a million warning messages if I do
> #undef __FUNCT__
> (i.e., file.cpp:XXX: __FUNCT__=“ClassName::FunctionName" does not agree with __func__=“FunctionName”)
> If I run the same code using intel15 compilers it’s the opposite (which I discovered just now). That is, I get an error for
> #undef __FUNCT__
> (i.e., file.cpp:XXX: __FUNCT__=“FunctionName" does not agree with __func__=“ClassName::FunctionName”)
> I do like the error handling by PETSc. I think it’s quite helpful. Obviously, I can write my own stack trace but why bother if it’s already there. I did check your online documentation and I could no longer find these definitions in your code. So, should I just remove all of these definitions? Is there a quick fix? Is this depreciated?
> Second of all, I saw you do no longer use error handling in your examples at all, i.e.,
> ierr = FunctionCall(); CHKERRQ(ierr);
> and friends have vanished. Why is that? Is it just to keep the examples simple or are you moving away from using these Macros for error handling.
> I hope I did not miss any changes in this regard in one of your announcements. I could not find anything in the documentation.
> Thanks
> Andreas
