[petsc-users] petsc4py --with-64-bit-indices
Aurelien Ponte
aurelien.ponte at ifremer.fr
Sun Dec 18 13:54:09 CST 2016
Here is what I am trying now:
setenv MPICC mpiicc
pip install --user --upgrade --ignore-installed --no-cache-dir mpi4py
pip install --user --upgrade --ignore-installed --no-cache-dir numpy
setenv PETSC_CONFIGURE_OPTIONS '--with-64-bit-indices --with-fc=mpif90
--download-fblaslapack'
pip install --user --upgrade --ignore-installed --no-cache-dir petsc
petsc4py
I get now the following error message (I'll send the logs to
petsc-maint at mcs.anl.gov as suggested):
CC
arch-python-linux-x86_64/obj/src/vec/is/is/interface/index.o
Fatal Error: Reading module mpi at line 1 column 2: Unexpected EOF
gmake[2]: ***
[arch-python-linux-x86_64/obj/src/sys/f90-mod/petscsysmod.o] Error 1
gmake[2]: *** Waiting for unfinished jobs....
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/client.c(3): warning
#161: unrecognized #pragma
#pragma clang diagnostic ignored "-Wdeprecated-declarations"
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/client.c(4): warning
#pragma gcc diagnostic ignored "-Wdeprecated-declarations"
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/google.c(3): warning
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/google.c(4): warning
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/box.c(3): warning
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/box.c(4): warning
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/globus.c(2): warning
/tmp/pip-build-t7pV1u/petsc/src/sys/webclient/globus.c(3): warning
gmake[2]: Leaving directory `/tmp/pip-build-t7pV1u/petsc'
gmake[1]: *** [gnumake] Error 2
gmake[1]: Leaving directory `/tmp/pip-build-t7pV1u/petsc'
**************************ERROR*************************************
Error during compile, check
arch-python-linux-x86_64/lib/petsc/conf/make.log
Send it and arch-python-linux-x86_64/lib/petsc/conf/configure.log
to petsc-maint at mcs.anl.gov
make: *** [all] Error 1
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-build-t7pV1u/petsc/setup.py", line 302, in <module>
**metadata)
File
"/appli/python/2.7.10_gcc-4.9.2/python-2.7.10/lib/python2.7/distutils/core.py",
line 151, in setup
dist.run_commands()
File
"/appli/python/2.7.10_gcc-4.9.2/python-2.7.10/lib/python2.7/distutils/dist.py",
line 953, in run_commands
self.run_command(cmd)
File
line 972, in run_command
cmd_obj.run()
File "/tmp/pip-build-t7pV1u/petsc/setup.py", line 219, in run
build(self.dry_run)
File "/tmp/pip-build-t7pV1u/petsc/setup.py", line 164, in build
if status != 0: raise RuntimeError(status)
RuntimeError: 512
Command "/appli/python/2.7.10_gcc-4.9.2/python-2.7.10/bin/python -u -c
"import setuptools,
tokenize;__file__='/tmp/pip-build-t7pV1u/petsc/setup.py';f=getattr(tokenize,
'open', open)(__file__);code=f.read().replace('\r\n',
'\n');f.close();exec(compile(code, __file__, 'exec'))" install --record
/tmp/pip-ebXwB3-record/install-record.txt
--single-version-externally-managed --compile --user --prefix=" failed
with error code 1 in /tmp/pip-build-t7pV1u/petsc/
Le 18/12/2016 à 16:52, Satish Balay a écrit :
> How about using --download-fblaslapack instead of MKL?
> Satish
> On Sun, 18 Dec 2016, Aurelien Ponte wrote:
>> Allright I got the following to complete:
>> ### install pip:
>> module load python/2.7.10_gnu-4.9.2
>> wget https://bootstrap.pypa.io/get-pip.py
>> python get-pip.py --user
>> # edit .cshrc: set path = ($path $home/.local/bin) + setenv LD_LIBRARY_PATH
>> /home1/caparmor/aponte/.local/lib:${LD_LIBRARY_PATH}
>> setenv MPICC mpiicc
>> pip install --user --upgrade mpi4py
>> pip install --user --upgrade numpy
>> --with-blas-lapack-dir=/appli/intel/Compiler/11.1/073/mkl/lib/em64t'
>> pip install --user petsc petsc4py
>> But now I get the following at run time:
>> *** libmkl_mc3.so *** failed with error :
>> /appli/intel/Compiler/11.1/073/mkl/lib/em64t/libmkl_mc3.so: undefined symbol:
>> mkl_dft_commit_descriptor_s_c2c_md_omp
>> *** libmkl_def.so *** failed with error :
>> /appli/intel/Compiler/11.1/073/mkl/lib/em64t/libmkl_def.so: undefined symbol:
>> MKL FATAL ERROR: Cannot load neither libmkl_mc3.so nor libmkl_def.so
>> Any ideas?
>> I will also try the other approach (from source).
>> thanks
>> aurelien
>> Le 17/12/2016 à 22:36, Lawrence Mitchell a écrit :
>>>> On 17 Dec 2016, at 19:19, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Looks like --install-option= are options for pip not the underlying
>>>> package.
>>>> Lisandro, how does one do what seems to be a simple request?
>>> Set PETSC_CONFIGURE_OPTIONS to any additional flags you want to pass to
>>> configure during pip install
Aurélien Ponte
Tel: (+33) 2 98 22 40 73
Fax: (+33) 2 98 22 44 96
UMR 6523, IFREMER
ZI de la Pointe du Diable
CS 10070
29280 Plouzané
