[petsc-users] Set saddle-point structure in parallel
Barry Smith
bsmith at mcs.anl.gov
Fri Dec 2 11:34:05 CST 2016
Each process needs to provide the IS that contain only local entries for that process.
It looks like you might be doing the opposite.
> On Dec 2, 2016, at 10:36 AM, Karin&NiKo <niko.karin at gmail.com> wrote:
> Dear all,
> Thanks to Matt's help, I have been able to set up a fieldsplit preconditioner for a Stokes-like problem. But it was in sequential! Now I am facing new issues when trying to set up the saddle-point structure in parallel.
> Well, I have a matrix with 38 DOF. In the global numbering, the pressure DOF are numbered : 2,5,8,11,14,17 and the velocity DOF are the others. The matrix is distributed on 2 procs, the rows 0 to 18 on proc0, the rows from 19 to 38 on procs1.
> I have set the following IS in order to pass them to the PCFieldSplit :
> call ISCreateGeneral(PETSC_COMM_SELF, nbddl0, vec_ddl0, PETSC_COPY_VALUES, is0, ierr)
> call ISCreateGeneral(PETSC_COMM_SELF, nbddl1, vec_ddl1, PETSC_COPY_VALUES, is1, ierr)
> This is what they contain :
> is0 on proc0 :
> IS Object: 1 MPI processes
> type: general
> Number of indices in set 19
> 0 19
> 1 20
> 2 21
> 3 22
> 4 23
> 5 24
> 6 25
> 7 26
> 8 27
> 9 28
> 10 29
> 11 30
> 12 31
> 13 32
> 14 33
> 15 34
> 16 35
> 17 36
> 18 37
> is1 on proc0 :
> type: general
> Number of indices in set 0
> is0 on proc1 :
> type: general
> Number of indices in set 13
> 0 0
> 1 1
> 2 3
> 3 4
> 4 6
> 5 7
> 6 9
> 7 10
> 8 12
> 9 13
> 10 15
> 11 16
> 12 18
> is1 on proc1 :
> type: general
> Number of indices in set 6
> 0 2
> 1 5
> 2 8
> 3 11
> 4 14
> 5 17
> Then I pass them to the FieldSplit :
> call PCFieldSplitSetIS(pc,'0',is0, ierr)
> call PCFieldSplitSetIS(pc,'1',is1, ierr)
> But when the PC is set up, PETSc complains about :
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: Nonconforming object sizes
> [1]PETSC ERROR: Local column sizes 32 do not add up to total number of columns 19
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> [1]PETSC ERROR: \C0\E3o on a arch-linux2-c-debug named dsp0780450 by B07947 Fri Dec 2 17:07:54 2016
> [1]PETSC ERROR: Configure options --prefix=/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/Install --with-mpi=yes --with-x=yes --download-ml=/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/ml-6.2-p3.tar.gz --with-mumps-lib="-L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/lib -lzmumps -ldmumps -lmumps_common -lpord -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Scotch_aster-604_aster6/MPI/lib -lesmumps -lptscotch -lptscotcherr -lptscotcherrexit -lscotch -lscotcherr -lscotcherrexit -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Parmetis_aster-403_aster/lib -lparmetis -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Metis_aster-510_aster1/lib -lmetis -L/usr/lib -lscalapack-openmpi -L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi -lblacsF77init-openmpi -L/usr/lib/x86_64-linux-gnu -lgomp " --with-mumps-include=/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/include --with-scalapack-lib="-L/usr/lib -lscalapack-openmpi" --with-blacs-lib="-L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi -lblacsF77init-openmpi" --with-blas-lib="-L/usr/lib -lopenblas -lcblas" --with-lapack-lib="-L/usr/lib -llapack"
> [1]PETSC ERROR: #1 MatGetSubMatrix_MPIAIJ_Private() line 3181 in /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: #2 MatGetSubMatrix_MPIAIJ() line 3100 in /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: #3 MatGetSubMatrix() line 7825 in /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/mat/interface/matrix.c
> [1]PETSC ERROR: #4 PCSetUp_FieldSplit() line 560 in /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [1]PETSC ERROR: #5 PCSetUp() line 968 in /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: #6 KSPSetUp() line 390 in /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/ksp/ksp/interface/itfunc.c
> I am doing something wrong but I cannot see how I should specify the layout of my fields.
> Thanks in advance,
> Nicolas
> <image.png>
> <Matrix38.ascii>
