[petsc-users] Set saddle-point structure in parallel
Karin&NiKo
niko.karin at gmail.com
Fri Dec 2 10:36:08 CST 2016
Dear all,
Thanks to Matt's help, I have been able to set up a fieldsplit
preconditioner for a Stokes-like problem. But it was in sequential! Now I
am facing new issues when trying to set up the saddle-point structure in
parallel.
Well, I have a matrix with 38 DOF. In the global numbering, the pressure
DOF are numbered : 2,5,8,11,14,17 and the velocity DOF are the others. The
matrix is distributed on 2 procs, the rows 0 to 18 on proc0, the rows from
19 to 38 on procs1.
I have set the following IS in order to pass them to the PCFieldSplit :
call ISCreateGeneral(PETSC_COMM_SELF, nbddl0, vec_ddl0, PETSC_COPY_VALUES,
is0, ierr)
call ISCreateGeneral(PETSC_COMM_SELF, nbddl1, vec_ddl1, PETSC_COPY_VALUES,
is1, ierr)
This is what they contain :
is0 on proc0 :
IS Object: 1 MPI processes
type: general
Number of indices in set 19
0 19
1 20
2 21
3 22
4 23
5 24
6 25
7 26
8 27
9 28
10 29
11 30
12 31
13 32
14 33
15 34
16 35
17 36
18 37
is1 on proc0 :
type: general
Number of indices in set 0
is0 on proc1 :
type: general
Number of indices in set 13
0 0
1 1
2 3
3 4
4 6
5 7
6 9
7 10
8 12
9 13
10 15
11 16
12 18
is1 on proc1 :
type: general
Number of indices in set 6
0 2
1 5
2 8
3 11
4 14
5 17
Then I pass them to the FieldSplit :
call PCFieldSplitSetIS(pc,'0',is0, ierr)
call PCFieldSplitSetIS(pc,'1',is1, ierr)
But when the PC is set up, PETSc complains about :
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Nonconforming object sizes
[1]PETSC ERROR: Local column sizes 32 do not add up to total number of
columns 19
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
[1]PETSC
ERROR:
\C0\E3o on a arch-linux2-c-debug named dsp0780450 by B07947 Fri Dec 2
17:07:54 2016
[1]PETSC ERROR: Configure options
--prefix=/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/Install
--with-mpi=yes --with-x=yes
--download-ml=/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/ml-6.2-p3.tar.gz
--with-mumps-lib="-L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/lib
-lzmumps -ldmumps -lmumps_common -lpord
-L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Scotch_aster-604_aster6/MPI/lib
-lesmumps -lptscotch -lptscotcherr -lptscotcherrexit -lscotch -lscotcherr
-lscotcherrexit
-L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Parmetis_aster-403_aster/lib
-lparmetis
-L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Metis_aster-510_aster1/lib
-lmetis -L/usr/lib -lscalapack-openmpi -L/usr/lib -lblacs-openmpi
-lblacsCinit-openmpi -lblacsF77init-openmpi -L/usr/lib/x86_64-linux-gnu
-lgomp "
--with-mumps-include=/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/include
--with-scalapack-lib="-L/usr/lib -lscalapack-openmpi"
--with-blacs-lib="-L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi
-lblacsF77init-openmpi" --with-blas-lib="-L/usr/lib -lopenblas -lcblas"
--with-lapack-lib="-L/usr/lib -llapack"
[1]PETSC ERROR: #1 MatGetSubMatrix_MPIAIJ_Private() line 3181 in
/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: #2 MatGetSubMatrix_MPIAIJ() line 3100 in
[1]PETSC ERROR: #3 MatGetSubMatrix() line 7825 in
/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/mat/interface/matrix.c
[1]PETSC ERROR: #4 PCSetUp_FieldSplit() line 560 in
/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[1]PETSC ERROR: #5 PCSetUp() line 968 in
/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/ksp/pc/interface/precon.c
[1]PETSC ERROR: #6 KSPSetUp() line 390 in
/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/src/ksp/ksp/interface/itfunc.c
I am doing something wrong but I cannot see how I should specify the layout
of my fields.
Thanks in advance,
Nicolas
[image: Images intégrées 1]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161202/1d13c1e7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161202/1d13c1e7/attachment-0001.png>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161202/1d13c1e7/attachment-0001.obj>
