[petsc-users] MatGetDiagonalBlock and shell matrices
Dave May
dave.mayhem23 at gmail.com
Fri Aug 26 08:22:09 CDT 2016
On Friday, 26 August 2016, Steven Dargaville <dargaville.steven at gmail.com>
wrote:
> Hi Dave
> Thanks for the response. I'm actually using fortran and I wasn't sure that
> PetscObjectComposeFunction would be accessible, and if so, what sort of
> fortran magic I might need to call this function (possibly an interface,
> with or without c_opt).
> Do you know if it is possible to call that routine directly from fortran?
I don't know. I'll have appeal to the other petsc users for an answer to
these questions.
Dave
> Thanks
> Steven
> On Fri, Aug 26, 2016 at 1:35 PM, Dave May <dave.mayhem23 at gmail.com
> <javascript:_e(%7B%7D,'cvml','dave.mayhem23 at gmail.com');>> wrote:
>> On 26 August 2016 at 14:34, Dave May <dave.mayhem23 at gmail.com
>>> On 26 August 2016 at 14:14, Steven Dargaville <
>>> <javascript:_e(%7B%7D,'cvml','dargaville.steven at gmail.com');>> wrote:
>>>> Hi all
>>>> I'm just wondering if there is any plans in the future for
>>>> MatGetDiagonalBlock to support shell matrices by registering a
>>>> user-implemented MATOP? MatGetDiagonal supports MATOP, but the block
>>>> version of this does not.
>>>> I found a previous query on the user list which touched on this and
>>>> mentioned that it would be easy to add:
>>>> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-May/008700.html
>>>> I have implemented a matrix-free multigrid algorithm using shell
>>>> operations in PETSc, and it would be very convenient to be able to provide
>>>> a local shell Mat so I could apply local GMRES (or other matvec-based
>>>> solvers) as a local block smoother.
>>> It looks like the thing you need to do is use
>>> PetscObjectComposeFunction() and not MatShellSetOperation()
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>> Sys/PetscObjectComposeFunction.html#PetscObjectComposeFunction
>>> with your MatShell object.
>>> That is, instead of calling MatShellSetOperation(), call
>>> ierr = PetscObjectComposeFunction(myshell,"MatGetDiagonalBlock_C",
>>> MatGetDiagonalBlock_MyShell);CHKERRQ(ierr);
>> Oops - I forgot the cast, the above should be
>> ierr = PetscObjectComposeFunction((PetscObject)myshell,"MatGetDiago
>> nalBlock_C", MatGetDiagonalBlock_MyShell);CHKERRQ(ierr);
>>> where MatGetDiagonalBlock_MyShell is a function pointer to your method
>>> to get the diagonal block.
>>> Important detail is that you don't change the string
>>> "MatGetDiagonalBlock_C". The method MatGetDiagonalBlock() does a function
>>> pointer query using this string. See
>>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/interface
>>> /matrix.c.html#MatGetDiagonalBlock
>>> Thanks
>>> Dave
>>>> Thanks!
>>>> Steven
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160826/d50fc4ae/attachment.html>
