[petsc-users] MatGetDiagonalBlock and shell matrices
Steven Dargaville dargaville.steven at gmail.com
Fri Aug 26 08:16:00 CDT 2016
Hi Dave
Thanks for the response. I'm actually using fortran and I wasn't sure that
PetscObjectComposeFunction would be accessible, and if so, what sort of
fortran magic I might need to call this function (possibly an interface,
with or without c_opt).
Do you know if it is possible to call that routine directly from fortran?
Thanks
Steven
On Fri, Aug 26, 2016 at 1:35 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 26 August 2016 at 14:34, Dave May <dave.mayhem23 at gmail.com> wrote:
>> On 26 August 2016 at 14:14, Steven Dargaville <
>> dargaville.steven at gmail.com> wrote:
>>> Hi all
>>> I'm just wondering if there is any plans in the future for
>>> MatGetDiagonalBlock to support shell matrices by registering a
>>> user-implemented MATOP? MatGetDiagonal supports MATOP, but the block
>>> version of this does not.
>>> I found a previous query on the user list which touched on this and
>>> mentioned that it would be easy to add:
>>> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-May/008700.html
>>> I have implemented a matrix-free multigrid algorithm using shell
>>> operations in PETSc, and it would be very convenient to be able to provide
>>> a local shell Mat so I could apply local GMRES (or other matvec-based
>>> solvers) as a local block smoother.
>> It looks like the thing you need to do is use
>> PetscObjectComposeFunction() and not MatShellSetOperation()
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>> Sys/PetscObjectComposeFunction.html#PetscObjectComposeFunction
>> with your MatShell object.
>> That is, instead of calling MatShellSetOperation(), call
>> ierr = PetscObjectComposeFunction(myshell,"MatGetDiagonalBlock_C",
>> MatGetDiagonalBlock_MyShell);CHKERRQ(ierr);
> Oops - I forgot the cast, the above should be
> ierr = PetscObjectComposeFunction((PetscObject)myshell,"MatGetDia
> gonalBlock_C", MatGetDiagonalBlock_MyShell);CHKERRQ(ierr);
>> where MatGetDiagonalBlock_MyShell is a function pointer to your method to
>> get the diagonal block.
>> Important detail is that you don't change the string
>> "MatGetDiagonalBlock_C". The method MatGetDiagonalBlock() does a function
>> pointer query using this string. See
>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/interface
>> /matrix.c.html#MatGetDiagonalBlock
>> Thanks
>> Dave
>>> Thanks!
>>> Steven
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160826/027a003a/attachment.html>
