[petsc-users] Implementation of Anderson mixing
Jonas Mairhofer
mhofer at itt.uni-stuttgart.de
Tue Aug 23 04:15:06 CDT 2016
Thank you for this fast response!
Am 22.08.2016 18:07, schrieb Barry Smith:
>> On Aug 22, 2016, at 7:36 AM, Jonas Mairhofer <mhofer at itt.uni-stuttgart.de> wrote:
>> Dear PETSc-Team,
>> I am having a bit of trouble understanding the way the Anderson mixing method is implemented inPETSc.
>> On the corresponding website (http://www.mcs.anl.gov/petsc/petsc-3.5/docs/manualpages/SNES/SNESAnderson.html) it says in the
>> "Option database" section
>> X_{update} = X + \beta F
> This is wrong, it is the "mixing" parameter. I will fix it.
>> which looks to me as if the new solution is calculated from the old solution plus something which depends on the old residual F.
>> However, in the "Notes" section it says that the new solution is found by combining "m previous solutions" which I interpret as the last m values of X.
>> In most other sources on Anderson mixing (e.g. the original one referd to on the website mentioned above) the update procedure looks something like
>> X^{k+1} = (1-\beta) \sum_{i=0}^{m} \alpha_i^k X^{k-m+1} + \beta \sum_{i=0}^m \alpha_i^k G(X^{k-m+i}) where G = F + X.
>> Therefore, the new value of X is calculated from the last m values of X and F.
>> Unfortunately, I was not able to understand and follow the actual source code in src/snes/impls/ngmres/anderson.c
> The computation of the \sum_{i=0}^{m} \alpha_i^k X^{k-m+1} and \sum_{i=0}^m \alpha_i^k G(X^{k-m+i} take place in
> 146: SNESNGMRESFormCombinedSolution_Private(snes,ivec,l,XM,FM,fMnorm,X,XA,FA);
> in particular the
> ierr = VecMAXPY(XA,l,beta,Xdot);CHKERRQ(ierr);
> (note this is NOT the same \beta it is more like the \alpha above).
> ierr = VecMAXPY(FA,l,beta,Fdot);CHKERRQ(ierr);
>> Could you please tell me whether the last values of X, F or both are used in the update scheme of PETSc's Anderson mixing implementation?
> Both are, see above.
>> And is \beta used in a "regular line search way" where X^{new} = X^{old} + \beta* "undamped update"
> No
>> or as in the equation above
>> X^{new} = (1-\beta) \sum "function of last m X" + \beta \sum "function of last m G"
> Yes.
> 142: VecAXPY(XM,-ngmres->andersonBeta,FM);
>> which would explain to me why beta is not set via -snes_linesearch_damping but using the extra option -snes_anderson_beta.
>> Thank you very much for your help!
>> Jonas
