[petsc-users] MatMkl_CPardisoSetCntl
Matthew Overholt overholt at capesim.com
Mon Aug 22 10:49:17 CDT 2016
Hi All,
I am using the Intel MKL CPardiso library as a PC direct solver, and I am
trying to figure out how to properly set options (the Pardiso and CPardiso
"iparm" parameter values in the Intel docs).
Q1: To set the Pivoting perturbation, for example, is the correct call:
ierr = MatMkl_CPardisoSetCntl( K, 10, 13 );
where the KSP matrix to be inverted is "K" and the value that I want is
"13"?  This is the "-mat_mkl_pardiso_10" option listed on the
MATSOLVERMKL_PARDISO page, and the "iparm[9]" option in the Intel docs.
Q2: Where do I make this call, before "MatSetUp( K )", at some point during
the creation and setup of KSP, or after calling
"PCFactorSetMatSolverPackage( pc, MATSOLVERMKL_CPARDISO )"?  I've tried many
different combinations and none of them seem to work.
Since the effect of changing the pivoting perturbation may not be obvious, I
also tried setting the number of OpenMP threads to use within Pardiso (icntl
= 65, without the environmental variable MKL_NUM_THREADS present) and my
setting was ignored (Pardiso defaulted to using the maximum number of cores
present).
Thanks in advance,
Matt Overholt
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160822/925d501c/attachment.html>
