[petsc-users] MatMkl_CPardisoSetCntl
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 22 13:39:51 CDT 2016
> On Aug 22, 2016, at 1:10 PM, Matthew Overholt <overholt at capesim.com> wrote:
>>> On Aug 22, 2016, at 10:49 AM, Matthew Overholt <overholt at capesim.com> wrote:
>>> I am using the Intel MKL CPardiso library as a PC direct solver, and I am trying to
>>> figure out how to properly set options (the Pardiso and CPardiso “iparm” parameter
>>> values in the Intel docs).
>> On Aug 22, 2016, at 12:32 PM, Barry Smith wrote:
>> The easy way to set these is via the options database so from the command line you
>> can use -mat_mkl_cpardiso_<icntl> <ival> for example -mat_mkl_cpardiso_10 13 or in
>> the code you can write PetscOptionsSetValue(NULL,"-mat_mkl_cpardiso_10","13"); make
>> sure that you call the PetscOptionsSetValue() BEFORE you call KSPSetFromOptions().
> Thanks, Barry, that is very helpful. I can successfully set some of the CPardiso parameters now from the command line (or otherwise, using the options database), but according to "-help" the only MKL_CPARDISO Options available are -mat_mkl_cpardiso_1 and _65 through _69. If I specify option 10 as you suggested I get a warning that the option was not used.
Hmm, looks like you need to run with
-mat_mkl_cpardiso_1 1
in order to get the other options like 10 to work. So for example
-mat_mkl_cpardiso_1 1 -mat_mkl_cpardiso_10 13
> I would like to get access to several other parameters to try and fix my zero pivot problem. How should I do that? Does the MKL interface make use of some -pc_factor* options (such as -pc_factor_zeropivot) when it calls CPardiso?
No it does not use these options.
> Thanks again,
> Matt Overholt
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
