[petsc-users] Question about using MatSNESMFWPSetComputeNormU
Thu Aug 18 14:05:19 CDT 2016
On Thu, Aug 18, 2016 at 2:03 PM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
> I got stuck at FormJacobian stage.
> - call SNESComputeJacobianDefault(snes, v, J, pJ, FormResidual, ier)  -->
> J & pJ are same with A matrix-free matrix (input argument)
> with these kind of messages..
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Mat type mffd
1) Always give the ENTIRE error message
2) As I said in the last two messages, you can only use this without a
preconditioner, so you need
  -pc_type none
    Matt
> Guess it's because I used A matrix-free matrix (which is mffd type) into
> pJ position.
> Is there any solution for this kind of situation?
> 2016-08-19 2:05 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>> On Thu, Aug 18, 2016 at 12:04 PM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
>>> Then in order not to use preconditioner,
>>> is it ok if I just put A matrix-free matrix (made from
>>> MatCreateSNESMF()) into the place where preA should be?
>> Yes, but again the solve will likely perform very poorly.
>>   Thanks,
>>      Matt
>>> The flow goes like this
>>> - call SNESCreate
>>> - call SNESSetFunction(snes, r, FormResidual, userctx, ier)
>>> - call MatCreateSNESMF(snes, A, ier)
>>> - call SNESSetJacobian(snes, A, A, FormJacobian, userctx, ier)
>>> - call SNESSetFromOptions()
>>> - call SNESGetKSP(snes, ksp, ier)
>>> - call KSPSetType(ksp, KSPGMRES, ier)
>>> - call KSPGetPC(ksp, pc, ier)
>>> - call PCSetType(pc, PCNONE, ier)
>>> - call KSPGMRESSetRestart(ksp, 30, ier)
>>> - call SNESSolve()
>>> and inside the FormJacobian routine
>>> - call SNESComputeJacobian(snes, v, J, pJ, userctx, ier)  --> J and pJ
>>> must be pointed with A and A.
>>> Thank you again,
>>> Kyungjun.
>>> 2016-08-19 1:44 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>> On Thu, Aug 18, 2016 at 11:42 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>> wrote:
>>>>> Thanks for your helpful answers.
>>>>> Here's another question...
>>>>> As I read some example PETSc codes, I noticed that there should be a
>>>>> preconditioning matrix (e.g. approx. jacobian matrix) when using
>>>>> MatCreateSNESMF().
>>>>> I mean,
>>>>> after calling MatCreateSNESMF(snes, A, ier),
>>>>> there should be another matrix preA(preconditioning matrix) to use
>>>>> SNESSetJacobian(snes, A, preA, FormJacobian, ctx, ier).
>>>>> 1) Is there any way that I can use matrix-free method without making
>>>>> preconditioning matrix?
>>>> Don't use a preconditioner. As you might expect, this does not often
>>>> work out well.
>>>>> 2) I have a reference code, and the code adopts
>>>>> MatFDColoringCreate()
>>>>> and finally uses
>>>>> SNESComputeJacobianDefaultColor() at FormJacobian stage.
>>>>> But I can't see the inside of the fdcolor and I'm curious of this
>>>>> mechanism. Can you explain this very briefly or tell me an example code
>>>>> that I can refer to. ( I think none of PETSc example code is using
>>>>> fdcolor..)
>>>> This is the default, so there is no need for all that code. We use
>>>> naive graph 2-coloring. I think there might be a review article by Alex
>>>> Pothen about that.
>>>>   Thanks,
>>>>     Matt
>>>>> Best,
>>>>> Kyungjun.
>>>>> 2016-08-19 0:54 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>> On Thu, Aug 18, 2016 at 10:39 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>>> wrote:
>>>>>>> 1) I wanna know the difference between applying option with command
>>>>>>> line and within source code.
>>>>>>> From my experience, command line option helps set other default
>>>>>>> settings that I didn't applied, I guess.
>>>>>> The command line arguments are applied to an object when
>>>>>> *SetFromOptions() is called, so in this case
>>>>>> you want SNESSetFromOptions() on the solver. There should be no
>>>>>> difference from using the API.
>>>>>>> 2) I made a matrix-free matrix with MatCreateSNESMF function, and
>>>>>>> every time I check my snes context with SNESView,
>>>>>>>     Mat Object:     1 MPI processes
>>>>>>>       type: mffd
>>>>>>>       rows=11616, cols=11616
>>>>>>>         Matrix-free approximation:
>>>>>>>           err=1.49012e-08 (relative error in function evaluation)
>>>>>>>           The compute h routine has not yet been set
>>>>>>> at the end of line shows there's no routine for computing h value.
>>>>>>> I used MatMFFDWPSetComputeNormU function, but it didn't work I think.
>>>>>>> Is it ok if I leave the h value that way? Or should I have to set h
>>>>>>> computing routine?
>>>>>> I am guessing you are calling the function on a different object from
>>>>>> the one that is viewed here.
>>>>>> However, there will always be a default function for computing h.
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> Kyungjun.
>>>>>>> 2016-08-18 23:18 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>>>> On Thu, Aug 18, 2016 at 8:35 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi, I'm trying to set my SNES matrix-free with Walker & Pernice
>>>>>>>>> way of computing h value.
>>>>>>>>> I found above command (MatSNESMFWPSetComputeNormU) but my fortran
>>>>>>>>> compiler couldn't fine any reference of that command.
>>>>>>>>> I checked Petsc changes log, but there weren't any mentions about
>>>>>>>>> that command.
>>>>>>>>> Should I have to include another specific header file?
>>>>>>>> We have this function
>>>>>>>>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpage
>>>>>>>> s/Mat/MatMFFDWPSetComputeNormU.html
>>>>>>>> but I would recommend using the command line option
>>>>>>>>   *-mat_mffd_compute_normu*
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>> Thank you always.
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160818/63747311/attachment-0001.html>
