[petsc-users] Question about using MatSNESMFWPSetComputeNormU
최경준
kyungjun.choi92 at gmail.com
Thu Aug 18 14:03:28 CDT 2016
I got stuck at FormJacobian stage.
- call SNESComputeJacobianDefault(snes, v, J, pJ, FormResidual, ier) --> J
& pJ are same with A matrix-free matrix (input argument)
with these kind of messages..
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Mat type mffd
Guess it's because I used A matrix-free matrix (which is mffd type) into pJ
position.
Is there any solution for this kind of situation?
2016-08-19 2:05 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
> On Thu, Aug 18, 2016 at 12:04 PM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
>> Then in order not to use preconditioner,
>> is it ok if I just put A matrix-free matrix (made from MatCreateSNESMF())
>> into the place where preA should be?
> Yes, but again the solve will likely perform very poorly.
> Thanks,
> Matt
>> The flow goes like this
>> - call SNESCreate
>> - call SNESSetFunction(snes, r, FormResidual, userctx, ier)
>> - call MatCreateSNESMF(snes, A, ier)
>> - call SNESSetJacobian(snes, A, A, FormJacobian, userctx, ier)
>> - call SNESSetFromOptions()
>> - call SNESGetKSP(snes, ksp, ier)
>> - call KSPSetType(ksp, KSPGMRES, ier)
>> - call KSPGetPC(ksp, pc, ier)
>> - call PCSetType(pc, PCNONE, ier)
>> - call KSPGMRESSetRestart(ksp, 30, ier)
>> - call SNESSolve()
>> and inside the FormJacobian routine
>> - call SNESComputeJacobian(snes, v, J, pJ, userctx, ier) --> J and pJ
>> must be pointed with A and A.
>> Thank you again,
>> Kyungjun.
>> 2016-08-19 1:44 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>> On Thu, Aug 18, 2016 at 11:42 AM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
>>>> Thanks for your helpful answers.
>>>> Here's another question...
>>>> As I read some example PETSc codes, I noticed that there should be a
>>>> preconditioning matrix (e.g. approx. jacobian matrix) when using
>>>> MatCreateSNESMF().
>>>> I mean,
>>>> after calling MatCreateSNESMF(snes, A, ier),
>>>> there should be another matrix preA(preconditioning matrix) to use
>>>> SNESSetJacobian(snes, A, preA, FormJacobian, ctx, ier).
>>>> 1) Is there any way that I can use matrix-free method without making
>>>> preconditioning matrix?
>>> Don't use a preconditioner. As you might expect, this does not often
>>> work out well.
>>>> 2) I have a reference code, and the code adopts
>>>> MatFDColoringCreate()
>>>> and finally uses
>>>> SNESComputeJacobianDefaultColor() at FormJacobian stage.
>>>> But I can't see the inside of the fdcolor and I'm curious of this
>>>> mechanism. Can you explain this very briefly or tell me an example code
>>>> that I can refer to. ( I think none of PETSc example code is using
>>>> fdcolor..)
>>> This is the default, so there is no need for all that code. We use naive
>>> graph 2-coloring. I think there might be a review article by Alex Pothen
>>> about that.
>>> Thanks,
>>> Matt
>>>> Best,
>>>> Kyungjun.
>>>> 2016-08-19 0:54 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>> On Thu, Aug 18, 2016 at 10:39 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>> wrote:
>>>>>> 1) I wanna know the difference between applying option with command
>>>>>> line and within source code.
>>>>>> From my experience, command line option helps set other default
>>>>>> settings that I didn't applied, I guess.
>>>>> The command line arguments are applied to an object when
>>>>> *SetFromOptions() is called, so in this case
>>>>> you want SNESSetFromOptions() on the solver. There should be no
>>>>> difference from using the API.
>>>>>> 2) I made a matrix-free matrix with MatCreateSNESMF function, and
>>>>>> every time I check my snes context with SNESView,
>>>>>> Mat Object: 1 MPI processes
>>>>>> type: mffd
>>>>>> rows=11616, cols=11616
>>>>>> Matrix-free approximation:
>>>>>> err=1.49012e-08 (relative error in function evaluation)
>>>>>> The compute h routine has not yet been set
>>>>>> at the end of line shows there's no routine for computing h value.
>>>>>> I used MatMFFDWPSetComputeNormU function, but it didn't work I think.
>>>>>> Is it ok if I leave the h value that way? Or should I have to set h
>>>>>> computing routine?
>>>>> I am guessing you are calling the function on a different object from
>>>>> the one that is viewed here.
>>>>> However, there will always be a default function for computing h.
>>>>> Thanks,
>>>>> Matt
>>>>>> Kyungjun.
>>>>>> 2016-08-18 23:18 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>>> On Thu, Aug 18, 2016 at 8:35 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi, I'm trying to set my SNES matrix-free with Walker & Pernice way
>>>>>>>> of computing h value.
>>>>>>>> I found above command (MatSNESMFWPSetComputeNormU) but my fortran
>>>>>>>> compiler couldn't fine any reference of that command.
>>>>>>>> I checked Petsc changes log, but there weren't any mentions about
>>>>>>>> that command.
>>>>>>>> Should I have to include another specific header file?
>>>>>>> We have this function
>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpage
>>>>>>> s/Mat/MatMFFDWPSetComputeNormU.html
>>>>>>> but I would recommend using the command line option
>>>>>>> *-mat_mffd_compute_normu*
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>> Thank you always.
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160819/07933a9f/attachment.html>
