[petsc-users] Question about using MatSNESMFWPSetComputeNormU
최경준 kyungjun.choi92 at gmail.com
Thu Aug 18 10:39:42 CDT 2016
1) I wanna know the difference between applying option with command line
and within source code.
>From my experience, command line option helps set other default settings
that I didn't applied, I guess.
2) I made a matrix-free matrix with MatCreateSNESMF function, and every
time I check my snes context with SNESView,
    Mat Object:     1 MPI processes
      type: mffd
      rows=11616, cols=11616
        Matrix-free approximation:
          err=1.49012e-08 (relative error in function evaluation)
          The compute h routine has not yet been set
at the end of line shows there's no routine for computing h value.
I used MatMFFDWPSetComputeNormU function, but it didn't work I think.
Is it ok if I leave the h value that way? Or should I have to set h
computing routine?
Kyungjun.
2016-08-18 23:18 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
> On Thu, Aug 18, 2016 at 8:35 AM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
>> Hi, I'm trying to set my SNES matrix-free with Walker & Pernice way of
>> computing h value.
>> I found above command (MatSNESMFWPSetComputeNormU) but my fortran
>> compiler couldn't fine any reference of that command.
>> I checked Petsc changes log, but there weren't any mentions about that
>> command.
>> Should I have to include another specific header file?
> We have this function
>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/
> MatMFFDWPSetComputeNormU.html
> but I would recommend using the command line option
>   *-mat_mffd_compute_normu*
>   Thanks,
>      Matt
> Thank you always.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160819/17505a8e/attachment.html>
