[petsc-users] A question about DMPlexDistribute
Matthew Knepley
knepley at gmail.com
Fri Aug 12 12:10:10 CDT 2016
On Thu, Aug 11, 2016 at 8:00 PM, leejearl <leejearl at 126.com> wrote:
> Thank you for your reply. I have attached the code, grid and the error
> message.
> cavity.c is the code file, cavity.exo is the grid, and error.dat is the
> error message.
> The command is "mpirun -n 2 ./cavity
Can you verify that you are running the master branch? I just ran this and
got
DM Object: 2 MPI processes
type: plex
DM_0x84000004_0 in 2 dimensions:
0-cells: 5253 5252
1-cells: 10352 10350
2-cells: 5298 (198) 5297 (198)
Labels:
ghost: 2 strata of sizes (199, 400)
vtk: 1 strata of sizes (4901)
Cell Sets: 1 strata of sizes (5100)
Face Sets: 3 strata of sizes (53, 99, 50)
depth: 3 strata of sizes (5253, 10352, 5298)
Matt
> On 2016年08月11日 23:29, Matthew Knepley wrote:
> On Thu, Aug 11, 2016 at 3:14 AM, leejearl <leejearl at 126.com> wrote:
>> Hi,
>> Thank you for your reply. It help me very much.
>> But, for "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c", when I set
>> the overlap to 2 levels, the command is
>> "mpirun -n 3 ./ex11 -f annulus-20.exo -ufv_mesh_overlap 2 -physics sw",
>> it suffers a error.
>> It seems to me that setting overlap to 2 is very common. Are there
>> issues that I have not take into consideration?
>> Any help are appreciated.
> I will check this out. I have not tested an overlap of 2 here since I
> generally use nearest neighbor FV methods for
> unstructured stuff. I have test examples that run fine for overlap > 1.
> Can you send the entire error message?
> If the error is not in the distribution, but rather in the analytics, that
> is understandable because this example is only
> intended to be run using a nearest neighbor FV method, and thus might be
> confused if we give it two layers of ghost
> cells.
> Matt
>> leejearl
>> On 2016年08月11日 14:57, Julian Andrej wrote:
>> Hi,
>> take a look at slide 10 of [1], there is visually explained what the
>> overlap between partitions is.
>> [1] https://www.archer.ac.uk/training/virtual/files/2015/06-
>> PETSc/slides.pdf
>> On Thu, Aug 11, 2016 at 8:48 AM, leejearl <leejearl at 126.com> wrote:
>>> Hi, all:
>>> I want to use PETSc to build my FVM code. Now, I have a question
>>> about
>>> the function DMPlexDistribute(DM dm, PetscInt overlap, PetscSF *sf, DM
>>> *dmOverlap) .
>>> In the example "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c".
>>> When I set the overlap
>>> as 0 or 1, it works well. But, if I set the overlap as 2, it suffers a
>>> problem.
>>> I am confused about the value of overlap. Can it be set as 2? What
>>> is the meaning of
>>> the parameter overlap?
>>> Any helps are appreciated!
>>> leejearl
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160812/858974e4/attachment.html>
