[petsc-users] A question about DMPlexDistribute
leejearl
leejearl at 126.com
Thu Aug 11 03:14:48 CDT 2016
Thank you for your reply. It help me very much.
But, for "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c", when I
set the overlap to 2 levels, the command is
"mpirun -n 3 ./ex11 -f annulus-20.exo -ufv_mesh_overlap 2 -physics sw",
it suffers a error.
It seems to me that setting overlap to 2 is very common. Are there
issues that I have not take into consideration?
Any help are appreciated.
leejearl
On 2016年08月11日 14:57, Julian Andrej wrote:
> Hi,
> take a look at slide 10 of [1], there is visually explained what the
> overlap between partitions is.
> [1]
> https://www.archer.ac.uk/training/virtual/files/2015/06-PETSc/slides.pdf
> On Thu, Aug 11, 2016 at 8:48 AM, leejearl <leejearl at 126.com
> <mailto:leejearl at 126.com>> wrote:
> Hi, all:
> I want to use PETSc to build my FVM code. Now, I have a
> question about
> the function DMPlexDistribute(DM dm, PetscInt overlap, PetscSF
> *sf, DM *dmOverlap) .
> In the example
> "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c". When I set the
> overlap
> as 0 or 1, it works well. But, if I set the overlap as 2, it
> suffers a problem.
> I am confused about the value of overlap. Can it be set as 2?
> What is the meaning of
> the parameter overlap?
> Any helps are appreciated!
> leejearl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160811/6ed88d55/attachment.html>
