[petsc-users] A question about DMPlexDistribute
Julian Andrej
juan at tf.uni-kiel.de
Thu Aug 11 01:57:47 CDT 2016
take a look at slide 10 of [1], there is visually explained what the
overlap between partitions is.
[1] https://www.archer.ac.uk/training/virtual/files/2015/06-PETSc/slides.pdf
On Thu, Aug 11, 2016 at 8:48 AM, leejearl <leejearl at 126.com> wrote:
> Hi, all:
> I want to use PETSc to build my FVM code. Now, I have a question about
> the function DMPlexDistribute(DM dm, PetscInt overlap, PetscSF *sf, DM
> *dmOverlap) .
> In the example "/petsc-3.7.2/src/ts/examples/tutorials/ex11.c". When
> I set the overlap
> as 0 or 1, it works well. But, if I set the overlap as 2, it suffers a
> problem.
> I am confused about the value of overlap. Can it be set as 2? What is
> the meaning of
> the parameter overlap?
> Any helps are appreciated!
> leejearl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160811/12ccd5cb/attachment.html>
