[petsc-users] TS and petscFE -unable to access u_t
Maximilian Hartig
imilian.hartig at gmail.com
Mon Aug 8 10:42:55 CDT 2016
Gladly. I also send the simple gmsh I am using.
Thank you,
Max
> On 08 Aug 2016, at 17:23, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 8, 2016 at 10:15 AM, Maximilian Hartig <imilian.hartig at gmail.com <mailto:imilian.hartig at gmail.com>> wrote:
> Thank you,
> I used these routines to setup a CN type TS. The problem I face now is that I seem to be unable to access the temporal derivatives u_t[..] for the definition of the residuals. I get a segmentation violation inside the PetscFEIntegrateResidual routine whenever I try to. I have attached the error message below.
> Also, I am wondering whether it is possible to update the neumann boundary condition of the FE object for each timestep. This would be useful for coupling purposes.
> Could you send you example so I can run it myself?
> Thanks,
> Matt
> Thank you,
> Max
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> [0]PETSC ERROR: or try http://valgrind.org <http://valgrind.org/> on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] PetscFEIntegrateResidual_Basic line 3503 /Users/maxhartig/PETSc/src/dm/dt/interface/dtfe.c
> [0]PETSC ERROR: [0] PetscFEIntegrateResidual line 5753 /Users/maxhartig/PETSc/src/dm/dt/interface/dtfe.c
> [0]PETSC ERROR: [0] DMPlexComputeResidual_Internal line 1706 /Users/maxhartig/PETSc/src/snes/utils/dmplexsnes.c
> [0]PETSC ERROR: [0] DMPlexSNESComputeResidualFEM line 2152 /Users/maxhartig/PETSc/src/snes/utils/dmplexsnes.c
> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal line 65 /Users/maxhartig/PETSc/src/snes/utils/dmlocalsnes.c
> [0]PETSC ERROR: [0] SNES user function line 2144 /Users/maxhartig/PETSc/src/snes/interface/snes.c
> [0]PETSC ERROR: [0] SNESComputeFunction line 2129 /Users/maxhartig/PETSc/src/snes/interface/snes.c
> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 150 /Users/maxhartig/PETSc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: [0] SNESSolve line 3961 /Users/maxhartig/PETSc/src/snes/interface/snes.c
> [0]PETSC ERROR: [0] TS_SNESSolve line 188 /Users/maxhartig/PETSc/src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: [0] TSStep_Theta line 206 /Users/maxhartig/PETSc/src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: [0] TSStep line 3700 /Users/maxhartig/PETSc/src/ts/interface/ts.c
> [0]PETSC ERROR: [0] TSSolve line 3921 /Users/maxhartig/PETSc/src/ts/interface/ts.c
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.2, unknown
> [0]PETSC ERROR: Configure options --download-triangle
> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>> On 03 Aug 2016, at 16:44, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Tue, Aug 2, 2016 at 8:22 AM, Maximilian Hartig <imilian.hartig at gmail.com <mailto:imilian.hartig at gmail.com>> wrote:
>> Hello all,
>> I would like to run a transient problem with PetscFE. Example ex11.c seems relevant since it uses the PestcFV context to create boundary conditions and RHS Functions for the TS.
>> Is there an easy way to do transient analysis with TS and petscFE or do I have to code my own time-stepping routine?
>> You can use
>> ierr = DMTSSetBoundaryLocal(adaptedDM, DMPlexTSComputeBoundary, user);CHKERRQ(ierr);
>> ierr = DMTSSetIFunctionLocal(adaptedDM, DMPlexTSComputeIFunctionFEM, user);CHKERRQ(ierr);
>> ierr = DMTSSetIJacobianLocal(adaptedDM, DMPlexTSComputeIJacobianFEM, user);CHKERRQ(ierr);
>> I have been meaning to write a heat equation example, but I have not finished yet,
>> Thanks,
>> Matt
>> Thanks,
>> Max
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/ea387eef/attachment-0003.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/ea387eef/attachment-0002.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/ea387eef/attachment-0004.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/ea387eef/attachment-0003.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/ea387eef/attachment-0005.html>
