[petsc-users] Question about SNESSetFunction - FormFunction part
Hong hzhang at mcs.anl.gov
Mon Aug 8 09:32:41 CDT 2016
You may take a look at our Fortran examples, e.g.,
petsc/src/snes/examples/tutorials/ex5f90t.F
Hong
On Mon, Aug 8, 2016 at 7:31 AM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
> Hi, my name is Michael Choi, currently working on applying SNES solver to
> my compressible Euler equation solver with Fortran90 language.
> I'm having an error like below
> [0]PETSC ERROR: ------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> I think my problem occurs at the position below.
> SNESSetFunction(SNES snes, Vec r, SNESFunction, ctx)
> and SNESFunction has the form like this.
> --> SNESFunction(SNES snes, Vec x, Vec f, ctx)
> From this definition, the user-defined function context (ctx; in my case,
> type variable) argument can be passed by only one argument. But I need
> three different data types for calculating residual in that subroutine
> SNESFunction.
> I tried using type pointer like below
> type(t_Collect) :: Collect
> Collect%pGrid => Grid
> Collect%pConfig => Config
> Collect%pMixture => Mixture
> I tried but pointers can not pass the SNESFunction argument.
> In this kind of situation, what should I have to do??
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/ecf016f9/attachment.html>
