[petsc-users] Question about SNESSetFunction - FormFunction part
    최경준
    kyungjun.choi92 at gmail.com
    Mon Aug  8 07:31:59 CDT 2016
Hi, my name is Michael Choi, currently working on applying SNES solver to
my compressible Euler equation solver with Fortran90 language.
I'm having an error like below
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
I think my problem occurs at the position below.
SNESSetFunction(SNES snes, Vec r, SNESFunction, ctx)
and SNESFunction has the form like this.
--> SNESFunction(SNES snes, Vec x, Vec f, ctx)
>From this definition, the user-defined function context (ctx; in my case,
type variable) argument can be passed by only one argument. But I need
three different data types for calculating residual in that subroutine
SNESFunction.
I tried using type pointer like below
type(t_Collect) :: Collect
Collect%pGrid => Grid
Collect%pConfig => Config
Collect%pMixture => Mixture
I tried but pointers can not pass the SNESFunction argument.
In this kind of situation, what should I have to do??
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160808/fe13154c/attachment.html>
