[petsc-users] vec norm for local portion of a vector
Patrick Sanan patrick.sanan at gmail.com
Tue Aug 2 05:18:37 CDT 2016
There is also VecGetLocalVector() and VecRestoreLocalVector() . You
should be able to use those to (copy-free, hopefully) obtain the local
entries of a global vector as a local vector which you could call the
usual VecNorm() on.
On Fri, Jul 29, 2016 at 4:41 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Jul 27, 2016, at 4:42 PM, Xiangdong <epscodes at gmail.com> wrote:
>> Hello everyone,
>> I have a global dmda vector vg. On each processor, if I want to know the norm of local portion of vg, which function should I call?
>> So far I am thinking of using DMDAVecGetArray and then write a loop to compute the norm of this local array.
>> Is there a simple function available to call? like *vg->ops->norm_local(vg,NORM_2, &normlocal)?
> There isn't a public interface to this call because it really isn't a mathematically well defined object; the subdomains in the decomposition of the array are arbitrary based on the number of processes used.
>    Anyways if you want it and it is the NON-overlapping portion then yes, you can write a little routine (basically just cut and paste VecNorm()) call it say VecNormLocal() and have it call the function pointer you indicated above. Note for the 2 norm the norm_local() returns the square of the norm so you need to take the square root.
>    If you want the overlapping portion of the vector then you should just do the DMDAVecGetArray() as you already do.
>    Barry
>> Thanks.
>> Best,
>> Xiangdong
